need suggestions on replacing stock 1jz-gte twin turbos!!!
wassup guys, so in the process of replacing all the old parts on my car.. the turbos start to smoke!!!, im fairly new with the 1jzgte... i don't really know much about the motor and the turbos... alot of people here gone single turbo.. and i need suggestions on which downpipe.. turbo size .. trim? ar?.. i have a hks 3inch downpipe to single exhaust, am i going to have to replace the downpipe if i get another turbo manifold??? i need your guys suggestions!!! and im on a budget... so telling me to go get a t78 isn't the right way to go hahahaha
i want to go single, but im not sure of how much the dp is going to cost or the turbo.. and if i replace these two items if ima have to get new injectors.. or a new ecu???
You could also consider using USDM 2JZ-GTE twins, they are not a bolt on but I have seen people adapt them to fit the manifold. If I remember correctly you can make a lot more power using USDM 2jz twins on a 1jz than if you were running stock 1jz twins.
Also if you are working with a budget of $1000 you most likely will not be able to afford a quality single turbo upgrade, especially when you factor in the supporting modifications to make 450whp!
