SC- 1st Gen (1992-2000)
Shifter Shaking
Old 02-08-09, 04:29 PM
UZZ30-SC4
UZZ30-SC4's Avatar
Default Shifter Shaking
Around 30 and 60 mph my shifter shakes side to side and rattles, its quite annoying lol. Any clues as to why its just starting to do such a thing? Tranny and engine mounts are fairly new (megan racing) only 10k on them. My torque converter is starting to slip more, i need to replace it, but i dont see it causing that oscillation.
Old 02-08-09, 05:07 PM
UZZ30-SC4
UZZ30-SC4's Avatar
bump . . . . . ..
Old 02-08-09, 05:08 PM
ThomasGS4
ThomasGS4's Avatar
I dunno
Old 02-08-09, 05:09 PM
bangdangvn
bangdangvn's Avatar
not sure if this is right but OLT said something about a flex coupler.
https://www.clublexus.com/forums/per...aft-bolts.html
Old 02-08-09, 05:15 PM
UZZ30-SC4
UZZ30-SC4's Avatar
Wow thanks! lol
Old 02-08-09, 05:49 PM
durtysc300
durtysc300's Avatar
mine does this as i'm braking
Old 02-08-09, 06:17 PM
Jewcano
No Sir, I Don't Like It
Jewcano's Avatar
Mine does it. All I did was wrap tape around the shifter part where the black bezel is and it doesn't move around it anymore . No more shaking during higher speeds
Old 02-08-09, 08:45 PM
tjschnei
tjschnei's Avatar
I had a similar issue with my SC3 but it was just while braking and it turned out to be a brake caliper locking up and caused my shifter to shake and was quite uncomfortable
Old 02-09-09, 12:45 AM
scENFORCER
scENFORCER's Avatar
Shifter vibrating? ..guess that's why they call it the 'dildomatic'
Old 04-18-14, 04:48 PM
t2d2
t2d2's Avatar
Kudos for this elegantly simple solution. Eventually, my bushing may need replacing, but no point doing all that disassembly/reassembly work when a bit of tape can quiet things down nicely. I even found some beige duct tape, but it wasn't quite a good enough color match for the shifter stalk, so I stuck with black electrical tape. It's barely noticeable as-is.
986ci's
Performance & Maintenance
02-29-12 06:53 AM
FlyLexus
02-01-03 07:38 AM
shmelvin
RX - 1st Gen (1999-2003)
12-27-02 06:49 AM
Quick Reply: Shifter Shaking
