SC- 1st Gen (1992-2000)
Old 12-12-14, 04:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
Print Wikipost
****Official Wheel & Tire Fitment Guide for SC300/SC400****
Old 07-10-14, 07:49 AM
  #5326
DoYuEvenSc
DoYuEvenSc's Avatar
Originally Posted by toyoboy120
With a roll and pull with smaller tires, yes you would be able to tuck.
Thanks a lot for all the help I thought I wouldn't be able to fit the tucked rim look with how aggressive the wheel was without getting fender flares or something like that
Old 07-10-14, 01:45 PM
  #5327
Southdwn77
Southdwn77's Avatar
Question adapter to 5x120 issues w/ stock suspension
Hey everyone...
stock everything on a 98 SC400.. was looking to acquire a set of 99 BMW 540i 20-spokes. One of my OEM wheels had to be recycled due to corrosion from Slime that was injected into the tire & the previous owner neglected to inform me about it. Anyway...
if my suspension is all stock... are there usually any problems with using an adapter to the 5x120 pattern of the BMW wheels?
I would love to just get a new wheel to match my OEM look, but Im on Oahu and finding a OEM 16" twisted 7-spoke chrome is not happening!
Old 07-10-14, 03:43 PM
  #5328
es30000000
es30000000's Avatar
18x9.5 +12 F with 225/40/18 and 18x10.5 +0 R with 245/40/18. Too aggressive? Because I'm about to pull the trigger.
Old 07-10-14, 05:32 PM
  #5329
OhHiChris
OhHiChris's Avatar
Will fit no problem with a roll. I'm running more aggressive specs but on 19s.
Old 07-10-14, 05:42 PM
  #5330
OhHiChris
OhHiChris's Avatar
Originally Posted by DoYuEvenSc
Hey everyone if you guys could help me I'm trying to get a set of SSR Vienna's. The specs are 19x9/10 +6/-1 is it possible to get pretty low on a set up like this?
Lol easy, specs are a little weak for the SC, so you will have no problem tucking. If you are tucking, you don't really need to stretch tires.
19x9.5 19x11 +19 in this pic, new wheels shipping in a few more weeks with more aggressive specs. Kinda old pic, running double digit negative offset up front right now with only a roll.
Old 07-10-14, 07:34 PM
  #5331
es30000000
es30000000's Avatar
Well based on your wheel specs, the ones I'm buying are more aggressive and you say they will fit with ease with just a roll... Yet your rear fenders are clearly pulled and you're on air?
Old 07-10-14, 09:37 PM
  #5332
OhHiChris
OhHiChris's Avatar
Like I said, old pics. Running negative offset 19x11s now. Yes I am on air, doesn't change anything. I can air up and do "static" fitment.
If you really want to get all technical with my old SSRs, your rear will be 12.7mm more aggressive. My rears are pulled because I wanted to tuck.
This is before the pull, yeah sits on the lip, so just run camber and you should be fine, or a pull if you don't want to rub. If you are too scared of rubbing, get less aggressive specs. Keep in mind this was before I got an alignment, this was all natural camber from airing out, sooo just pull a little bit, it is not too hard, I did mine with a friend (since I have my own roller) and just take your time or pay someone to do it.
Old 07-10-14, 11:30 PM
  #5333
DoYuEvenSc
DoYuEvenSc's Avatar
Dang really? I've seen your Sc and that is what gave me the wants to do a tucked 19 wheel your car is actually my favorite haha. Also you are running the wheels I've always wanted to get
Old 07-11-14, 10:47 AM
  #5334
OhHiChris
OhHiChris's Avatar
I would say go 18s if you want to be static, 19s if you are bagged. 19s will make you sit really high off the ground. If you really want to tuck, you will need to max your rear camber with those specs also roll completely flat (you don't want the lip to hit the inside of the fender) I have had that happen. Maybe a 5mm pull will do to make those specs tuck. But I still suggest going 18s.
Old 07-11-14, 10:58 AM
  #5335
DoYuEvenSc
DoYuEvenSc's Avatar
Thanks for all the kind words really appreciate it. I was actually worried about that same reason you posted about with being static and running 19s.
Old 07-14-14, 07:14 PM
  #5336
NomadJones
NomadJones's Avatar
Anybody have Mazda Millenia chrome rims on their SC?
I have a '98 SC400, and I'm looking at the 17x7 Mazda Millenia chrome rims from 1999-2002. They have a 55mm offset. Have to assume I can replace the Mazda caps with blanks.
Was hoping to get Supra TT MKIV wheels, but can't seem to find them cheap. These look good, although I wish it didn't have the ridge on the spokes. I'd really appreciate any thoughts, thanks.
Old 07-15-14, 01:03 PM
  #5337
bigwes
bigwes's Avatar
You will need a roll and a pull in the rear to get that to fit.
Old 07-16-14, 03:53 PM
  #5338
zedex22
zedex22's Avatar
fianlly got my new wheels and tires on
enkei sr6s with toyo proxes t1 sports -- 18" with 245 40R18s all around
****Official Wheel & Tire Fitment Guide for SC300/SC400****-zedexlex.jpg
River2016 (02-03-22)
Old 07-17-14, 08:40 PM
  #5339
fmayi1101
fmayi1101's Avatar
Default camber
Prob dumb question cause never seen done but recently a lic of one jn japan came up, anyone know of a kit that a help run double digit camber or a way of achieving.
Old 07-20-14, 06:36 AM
  #5340
Biddles
Biddles's Avatar
Guys I need some quick help, I'm about to buy some used 2007 IS250 17" OEM wheels. I believe they are 45 offset, and 8" wide. Will these rub anything on stock SC400 set up?
Quick Reply: ****Official Wheel & Tire Fitment Guide for SC300/SC400****
