SC- 1st Gen (1992-2000)
Heat from the firewall entering cabin
Old 06-01-11, 08:39 PM
  #76
TechGreek
TechGreek's Avatar
Originally Posted by O. L. T.
See that metal rod under it? It connects to the unit and moves via the hydraulic action inside the cylinder. Simply remove the arm from the dome and manually move the latch on the bottom of the heater control valve. Turn your heat on in your car and if you do not feel heat after doing this, you are set and ready! Give it a few minutes to cool down since there is still heat in the core, letting the car sit a while is a good idea too just to be sure.
I love you, you just solved my driving my self crazy for two months trying to figure out why my AC wasn't cold enough (seems the heater core was heat soaking the evaporator I guess because it's older can't keep up with good old 100* weather in LA).
A/C is ice cold now!
Old 09-12-14, 11:12 PM
  #77
net4n6
net4n6's Avatar
I am officially belong to the heated cabin club. I searched for solution and found this thread but no solution yet.
Please help. The temperature is in the 90 in So. Cal now. On the good side, the AC is freezing cold.
Old 09-17-14, 06:24 AM
  #78
aussie2013
aussie2013's Avatar
I would suggest replacing the valve for the heater in the radiator water line as it would seem to corrode up with age and not close properly, also some thermo tape on the exhaust , and the heat mat that is readily available form most car acc shops, put the heat mat on firewall inside and out.
Old 09-17-14, 08:20 AM
  #79
net4n6
net4n6's Avatar
Originally Posted by aussie2013
I would suggest replacing the valve for the heater in the radiator water line as it would seem to corrode up with age and not close properly.
You mean the thermostat?
Old 10-02-14, 05:20 PM
  #80
t2d2
t2d2's Avatar
net4n6, thanks for bumping this old thread. I've been trying to solve the same hot vent air problem as some of the people here and couldn't get much input on how far the heater control valve is supposed to rotate. OLT's suggestion brought me full circle to suspecting it wasn't closing all the way.
A little insight.....
When i experienced this problem i went out under the hood and manually closed off the heater core control valve and removed the arm so it couldn't re-open. Since then i have been heat free.
It seems the control valve never seems to fully close, especially if the air is off. Give it a shot, i have been very happy since i did.
rugmankc
RX - 4th Gen (2016-2022)
08-08-18 10:07 AM
Kwik8276
05-22-14 03:58 PM
aypues
10-12-11 02:56 AM
exodus_2
Automotive Care & Detailing
06-22-10 06:37 AM
Quick Reply: Heat from the firewall entering cabin
