SC- 1st Gen (1992-2000)
Crusty 94 chrome wheels
Old 02-06-17, 05:04 AM
Modenaro
Modenaro's Avatar
Default Crusty 94 chrome wheels / other Lexus wheel options?
Aside from 92-2000 SC300 wheels, what other Lexus 16" wheels will fit a 94? Thanks
Old 02-06-17, 08:26 AM
Modenaro
Modenaro's Avatar
Found a 16" set from a 95 SC300 with 225/60r16's installed.
Older tires are on the rims. Is 225/60r16 the next size up common size used on SC's from the stock 225/55R16 size?
Thanks
Old 02-06-17, 11:11 AM
jadu
live.love.laugh.lexus
jadu's Avatar
Thanks
According to discounttire, 60 profile is not listed an optional tire size. It is 5% taller tire, which would yield your odometer to read slower. I'd go with the original 225/55/16 or 235/55/16
Old 02-06-17, 12:05 PM
KahnBB6
KahnBB6's Avatar
Received 1,221 Likes on 856 Posts
The 1996 SC400 factory "blade" wheels with that tire size are a very good looking 16-inch rim on these cars. Best in painted gray but they also came in factory chrome versions. Note that you can't use any upgraded four-piston brake calipers with 16-inch wheels. SC400 factory brake calipers are the largest that can be fitted in this size.
Old 02-06-17, 03:47 PM
Modenaro
Modenaro's Avatar
I picked up the 6 spoke 95 SC300 wheels...... Better than the chrome turbine blade 15's.
Not a fan of chrome wheels, but the chrome is in great shape and at $100.00 for the set of 4. could not pass it up.
Old 02-10-17, 12:44 PM
t2d2
t2d2's Avatar
Do you plan to paint the center caps chrome colored? That looks pretty weird like that. I imagine they'd actually look better without the caps than with the mismatched colors.
An indirect answer to the original question: MKIV Supra NA wheels are 16", as opposed to the TT wheels which are 17". The NA wheels go pretty cheap, since everyone wants the TT ones for bigger caliper clearance. One of my cars actually came with a NA wheel as the spare, which tells you how high of demand they're in.
Old 02-17-17, 05:31 AM
Modenaro
Modenaro's Avatar
Passed Ca. smog today. Its 1st one in over 10 yrs. No problem.......
GS300916
GS - 1st Gen (1993-1997)
10-11-10 11:20 AM
lexsc3
Wheels, Tires & Brakes Forum
04-05-06 05:39 PM
faiello
02-19-06 07:35 AM
FireCode
08-07-03 12:43 PM
Quick Reply: Crusty 94 chrome wheels
