SC- 1st Gen (1992-2000)
92 sc300 bad ecu?
Old 09-12-16, 06:05 PM
mmac0405
mmac0405's Avatar
Default 92 sc300 bad ecu?
I bought a 92 sc300 auto 2 weeks ago had about 35 min drive home, it was bucking a little bit also transmission was shifting weird almost like hesitating but got the car home. So today I pull the car out of the garage to continue gutting the interior and notice the tach and speedo are not working now. I did some searching and it seems like it possible the ecu is going bad or its a bad ground, any input? NO cel is on.
Old 09-12-16, 06:23 PM
mmac0405
mmac0405's Avatar
After more searching I am going to pull the ecu and send to tanin
Old 09-12-16, 07:11 PM
Teal Sc400
Teal Sc400's Avatar
Open the ECU up before sending out and look for any leaking capacitors. My opened ECU (below pic) due to codes, for the Trac/abs. I had the brake fluid flushed which seemed to solve my problems luckily. Forgot to mention even with no leaking capacitors they still could be damaged.
Old 09-13-16, 05:09 PM
mmac0405
mmac0405's Avatar
Heres my ecu i didnt notice anything unusual
Attached Thumbnails 92 sc300 bad ecu?-20160913_181020.jpg   92 sc300 bad ecu?-20160913_181041.jpg   92 sc300 bad ecu?-20160913_181053.jpg
Old 09-13-16, 08:39 PM
Teal Sc400
Teal Sc400's Avatar
ECU Looks clean, but did u check for the codes, causing possible problems? Follow these steps on getting codes/solutions in correcting possible problems other then the ECU.
http://www.lexls.com/tutorials/intro/codereading.html#
riobanks
Performance & Maintenance
01-26-14 01:26 PM
Trax
01-31-13 04:50 PM
Bender25
09-17-12 07:25 PM
Rising_Sun
05-01-09 01:32 PM
Quick Reply: 92 sc300 bad ecu?
