SC- 1st Gen (1992-2000)
Anyone what this module thingy in driver fender functions as
Old 09-11-16, 02:04 AM
ar3
ar3's Avatar
Default Anyone know what this is in the driver side fender?
So I've been trying to get my horn to work. Today I replaced the clockspring but unfortunately that didn't solve the issue. I noticed this module looking thing that bolts on the driver fender toward the driver.
There were two thin wires (red/blue striped wire and a white wire) that were cut, I'm guessing tires rubbed through them. My harness is fine I relocated that already but it was just these wires that seemed problematic.
Does anyone have an idea what these are for?
Old 09-11-16, 03:48 PM
ar3
ar3's Avatar
Did some researching and they are DOOR BUZZER for the wireless key entry system. For anyone curious.
Old 09-11-16, 04:38 PM
t2d2
t2d2's Avatar
As in, the audible chirp? That's useful to know, in case I say, wanted to hook air horns up to it. Fun in parking lots.
Old 09-11-16, 08:02 PM
ar3
ar3's Avatar
yeah it's that chirp for the remote key. I'm gonna have to Jerry rig an air horn too if I don't get this damn stock horn issue solved.
Old 09-11-16, 09:05 PM
t2d2
t2d2's Avatar
I assume you've checked fuses?
Old 09-11-16, 10:17 PM
ar3
ar3's Avatar
Fuses good.
Relay good. clicks.
Clockspring good.
I found this connector under coolant reservoir /pics attached. How many horns do we have? I have one horn on the driver side behind radiator and a chirp horn one near driver strut mount. Is there supposed to be another horn here?
Attached Thumbnails Anyone what this module thingy in driver fender functions as-img_1065.jpg   Anyone what this module thingy in driver fender functions as-img_1066.jpg
Old 09-11-16, 11:00 PM
t2d2
t2d2's Avatar
That's your ambient temperature sensor. It should go through the opening down below and clip into the bottom of the bumper support, but they're so tough to un-clip, they seem to be broken off frequently and just set in the grill somewhere.
There are two regular horns in front of the radiator -- one up high (driver's side) and one down low (passenger side) -- and the alarm horn on the driver's side strut tower. Plus the chirp module you found.
Old 09-12-16, 03:14 PM
ar3
ar3's Avatar
Alright so I can't find the low tone horn. Only one I see is the high torn. I ordered a set of high and low on eBay I'll update if those work. I'll check the voltages too to rule out the wires.
GS408
Suspension and Brakes
06-22-17 07:31 PM
Quick Reply: Anyone what this module thingy in driver fender functions as
