SC- 1st Gen (1992-2000)
Control arms
Old 04-14-16, 06:21 PM
doozy
doozy's Avatar
Default Control arms
So my steering wheel is extremely loose when i turn it, I took it to a mechanic for something else and he mentioned that I needed to change my control arms. Does that usually mean its the upper control arms or lower?
Old 04-14-16, 07:00 PM
Ramblerman
Ramblerman's Avatar
Guess you would need to ask him which ones he meant. Bottom ones bear the most load & also are the most expensive, but mk 4 supra arms will fit & are supposed to cost less. Upper arms don't cost near as much & dormans seem to be the cheapest.
Old 04-14-16, 07:07 PM
BiGEZ
BiGEZ's Avatar
Most likely it is you lower control arms either the ball joint or bushings are bad. Did your mechanic also looked at you tie rods ends and sway bar bushing? these can contribute to sloppy handling as well.
As mentioned above you can replace them with Supra controls arm which are cheaper then the Lexus units. No after market LCA except for Megans, FIGS and battle version.
Old 04-14-16, 07:46 PM
doozy
doozy's Avatar
Thank you for all the replies. The mechanic didnt go into detail on what he did or didnt check, can you please direct me to the correct site or google search word to find these lower control arms? Im going to check the car out with a friend mechanic but since i havent been able to get a hold of him lately i wanted your opinions
Old 04-15-16, 12:52 AM
BiGEZ
BiGEZ's Avatar
You can shop around online and with your local Toyota Dealers for the 93-96 Toyota Supra lower control arms. They are between $250-$300 each and are a direct bolt on for the SCX00. The OEM Lexus units are about $600 each.
P/N's are 4806814080, 4806914080. I have a brand new driver side LCA listed in the FS section here.
20GS300
12-17-14 04:52 PM
SC510
Suspension and Brakes
12
05-27-14 07:00 AM
FuMoFFuTT
06-17-09 07:49 PM
tcd300
08-10-08 12:54 AM
sonyman
06-28-05 03:50 PM
Quick Reply: Control arms
