SC- 1st Gen (1992-2000)
New headlamps?
Old 08-03-13, 09:53 AM
redmanV8
redmanV8's Avatar
Default New headlamps?
So im tired of buffing my headlamps every month and the nasty condensation just ruins the look of the car. I dont want to open them to buff the inside, plus i want to get an hid kit soon wich i hear are awful with our stock projector. I read a thread here on 2000 headlamps with better projectors. Does anyone know which places to buy them and get a good deal? i see them on carsontoyota for 405 each, should i go with them?
Old 08-03-13, 11:31 AM
Dx3
Dx3's Avatar
Try Pembroke Pines.
Old 08-04-13, 08:20 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
If you have condensation inside your headlamp, that means your housing has a crack somewhere. Locate that crack in the headlamp housing, silicone it so no air can get in, then wait and the next day...no condensation!
Old 08-06-13, 07:18 AM
redmanV8
redmanV8's Avatar
im thinking of converting to HID so i really want the cut off line of the newer headlamps
Old 08-06-13, 09:30 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
HID's might solve the problems, might not. Even if you do install them, I will still say that you will see the fine particles on the lens itself. I say take them apart and buff those lens cover and the lens on the projector itself, reseal, then install the HID's. Anything over 6K will be useless, due to the projectory of the lens itself. This is my personal experience with them. After I did this, it was completely night and day difference. I also say buy the 55 Watt Ballast's, not the standard 35 watt. Much brighter IMO. I bought mine off of Ebay and they come with a 3 year warranty, for less than 75 shipped to the door. GL, in your choice.
Old 08-06-13, 01:30 PM
Kohinoor
Kohinoor's Avatar
iirc new headlights are about $600 for the pair at parts.com
whatever hid kit you buy, be sure to use a relay
Old 08-06-13, 01:34 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Use a relay for what? The HID kits that I have seen are plug and play. No relay needed. Am I lost or something???
Old 08-06-13, 01:50 PM
Blkexcoupe
Blkexcoupe's Avatar
It's a little more than 700 now, but still a better deal than most dealers.
A relay is used to provide power directly from the battery. The wiring on our cars is old, so a plug and play hid kit can potentially fry the stock wiring. A relay is only a few bucks and isn't that hard to wire in as an added precaution.
Old 08-06-13, 02:00 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I have many relays for things n my car, like the IACV, Ignitor, fuel pump, AEM, etc, but never for lighting. Maybe I need to look into this and run the remote turn on from the stock wiring, to trigger the relay on.
Old 08-06-13, 10:30 PM
redmanV8
redmanV8's Avatar
just wanted to do what this guy did https://www.clublexus.com/forums/sc-...-off-line.html
,i want to make sure i get the right parts he says 97+ have better projectors, i dont think buffing mine will get this result so i thought it would be the best direction to go in. also would like to know if anyone else has bought these for older models and how much difference it makes?
Gjohnson
02-26-18 06:09 AM
mckellyb
RX - 1st Gen (1999-2003)
06-17-14 07:18 AM
Spiziked23
11-18-12 07:01 PM
Muti007
GX - 1st Gen (2004-2009)
23
03-22-12 03:39 PM
JDM RICE
GX - 2nd Gen (2010-2023)
05-12-10 10:10 AM
Quick Reply: New headlamps?
