SC- 1st Gen (1992-2000)
Door has to be slammed to close properly...
Old 04-25-13, 06:31 PM
718murdoc
718murdoc's Avatar
Default Door has to be slammed to close properly...
Has anyone figured out a solution for this problem on the SC300/400? Some say it has to do with the air pressure in the cabin; but on my SC, it's the passenger door that gives me this problem. I have to open the window a bit for passengers that enter my car so they don't have to slam the door shut getting in or out. My drivers door is fine. For a while I thought it was a misaligned door latch, but the latch is fine.
Old 04-25-13, 07:34 PM
LEXXIUM
LEXXIUM's Avatar
Roll the window down on your side when your passengers get out, and roll it back up when they shut the door
Old 04-25-13, 11:36 PM
durps
durps's Avatar
Just get a jack, jack door to level, loosen bolts, jack door up about an inch, tighten bolts, and youre done.
Worked for me.
Old 04-25-13, 11:58 PM
1sWt2GS
1sWt2GS's Avatar
Worked for me.
this.
use a microfiber so the bottom of your door doesn't scratch
Old 04-26-13, 12:15 AM
durps
durps's Avatar
Also jack closer to the hingle/mirror half of the door, not the door handle half of the door.
Old 04-26-13, 04:37 AM
718murdoc
718murdoc's Avatar
Worked for me.
Originally Posted by 1sWt2GS
this.
I'll check this and see what happens. thanks for the info.
Old 04-26-13, 07:18 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
Doesn't help that the door itself is 100+ pounds.
Old 04-26-13, 12:44 PM
GamblerZ
GamblerZ's Avatar
It is most probably time to get the door hinge rebuilt/replaced.
Old 04-26-13, 05:05 PM
MXT4life
MXT4life's Avatar
Never noticed that leaving the window cracked when closing the door made it somewhat easier haha
Old 04-28-13, 07:47 AM
yell0w
yell0w's Avatar
You should also check where the front fender and the door meet. If you see a little paint missing it's probably because of your hinge causing your door to sag just enough causing it to rub on the front fender. Just something easy to look for.
TitanG545 (05-08-20)
vinsonF
IS - 1st Gen (2001-2005)
05-03-15 03:29 PM
bagyo
06-28-13 03:29 PM
Dai Kaiju
03-24-12 06:35 PM
hihopes
20
02-20-12 09:54 PM
Quick Reply: Door has to be slammed to close properly...
