View Poll Results: how was my first thread?
GREAT
42.86%
alright
42.86%
meh
14.29%
try harder lol
0%
Voters: 7. You may not vote on this poll
OEM VOLUME BUTTON OTHER USES/HORN FIX for people with quick release steering wheel
THIS CAN BE USED FOR ANYTHING YOU WANT TO HOOK UP TO BUTTON
okay so I recently got a woodgrain quick release now I was going to rig a horn up to the steering wheel but I decided since I don't use the volume button for the oem radio I might as well put it to use(I don't use it because my double din hass its own button)
Needed
solder/ soldering gun
wire/wire cutter of some sort
Phillips screwdriver
preferably wire taps
mini Phillips screw driver
AND a little bit of patience
so first you will take out your dash and steering wheel
now detach this guy from your trim of the center console you will need a Phillips for that
now you will have to open it up there are 6 mini screws you need to take out of the circuit board.
also some side clips to push in when pulling it out
this is what you will have. you will now need the solder and gun
solder the wires to these guys it does not matter which because the whole system is one big negative wire (make sure one wire is long enough to go from your dash to the steering wheel. id say about a foot and a half to be safe) other wire is just being grounded
best to hold these wires both to a ground and push the volume button it to make sure you connected right
Needed
now I took out the two little blue bulbs and pulled the wire through here, my other option which I tried just didn't want to play around with it long was melt two holes in the side of the plastic casing with the solder gun for the wire to come through. you pick.
now screw the screw the board back in with the mini screws
now screw the whole thing back into the console trim
take your longer wire through the back console of the driver side and have it come out by your pedals, now thread it up to your steering column
self tap the wire to the green wire or cut and connect
connect your shorter wire to a ground. I used one of the screws holding the double din in
push the volume (your new horn button) again to make sure you have a solid connection
green-horn red-cruise power peach-cruise speed brown-cruise power orange- 0 grey-0
black white red white/black olive black
NOW PUT YOUR CONSOLE TOGETHER AND YOUR WHEEL AND ENJOY YOUR NEW HORN ( I use my knee to beep my horn...just sayin) I have a video on The sc crew on facebook I am james swain
Keeper of the light
Well, if it works for you then it was a good mod. It's impractical and not one of those everybody is gonna drop what they are doing and make theirs kind of thing, but in terms of just doing something you need and making it work in your favor, then cool beans.
black- horn white-cruise power red-cruise speed white/black- cruise power olive-0 black-0
yeah just put it together for a couple people who were asking. it isn't for everyone I was fine without a horn so it doesn't really matter but it does also show how to wire something else up to this switch
Pretty cool tip man, I'm going to be upgrading my radio and I'd hate to have a button that does nothing there. I'll try and think about something else other then the horn though because I'm going for the RX 300 steering wheel conversion and I'll have a horn, but we'll see what happens. Quick question, what model double din radio do you have installed there?
1JZ Single SC400
Pretty cool idea. Its what you like, thats all that matters. I havent seen anyone use this for an Epicenter control **** by Audio Control. All the major stereo geeks will know what that is!!!
hmmm that is actually a sweet idea! please try it and let me know. might have to change the care around haha
