SC- 1st Gen (1992-2000)
Fastest r154 sc300? Pics of my setup.
Old 01-03-13, 08:27 PM
  #46
blk&blu*j
blk&blu*j's Avatar
Originally Posted by Vrank
Blk&blus last 2nd to last post was on the money. At right around 400whp and beating the **** out of my car doing dig runs my trans is on it's last leg in a car 400lbs plus lighter than an sc. The 1-2 shift is gonna be the killer. If your goal is 1/4 mile go auto. Also, please dyno the car with the cams before and after the sheet metal intake. Also curious to see how long your stock bottom end lasts on this setup.
^^^^^^^^^^^^^^^ R-154 not a track trans.X$5000.00 for a real trans. On debit Master Card. LOL
V160 if you wanna shift that -hit or a glide for racing on the cheap.
I have a fresh built glide for sale complete.!!!
LMK
Old 01-03-13, 08:41 PM
  #47
preston145
preston145's Avatar
Originally Posted by blk&blu*j
Glad to see you took my advice on the way small rear housing the BW will be a little lower in the hp # but will make up for it in reliability compared to the PTE.
I would recommend you weld a 90 on that turbo before you start running 30+ psi.
Also the R154 does not like drag racing abuse and you will destroy it in very short order, (3200+# cars) and you will find clutches to support those #'s are pricey and hard to come by.
Also at the 8-900 mark on E-fuel your torque will be maxing out the stock rod very easily and then Main caps also become a serious concern.
Just trying to help.
Yes the hotside was the culprit indeed, and both turbos will have a welded 90, my r154 was sent to Marlin Crawler and i had there HD kit done to it so i will see how how it does. it's not some stock r154. if it blows ill be installing a v160 or a th400 more then likely a v160 as I dont drag too much, but i do from time to time. It's more of a fun street car so I'll most likely go v160.
I have pushed over 500ftlbs for over a year on a stock r154 with no problem ever dumping the clutch. Never had a issue. i run mt90 maybe that helped. And i'll talk to my tuners at batlground i'm sure i can get that done for so we can see if the gains are worth it. The stock bottom end should be just fine, If it blows then i'll build.
LMK
Again I'm hoping the MC r154 I have does a good job, i'll see if it can posts some good times with her. If she pops v160 or th400 and Ill call her a day. Thanks for the replys and advice guys.
Old 01-03-13, 08:52 PM
  #48
blk&blu*j
blk&blu*j's Avatar
I had a complete R 154 MC tranny in 2006-2007 years and had pretty good success but the tranny will suffer a horrible demise on drag or even an ET street tire when it hooks and you will break the short axel in the SC with a auto diff Welded, the wheel hop is the killer.
Old 01-04-13, 05:46 AM
  #49
Vrank
Vrank's Avatar
And don't cheap out and get a torsen. Trd diff. Car is gonna be a handful. Definitely jealous.
Old 01-04-13, 06:16 AM
  #50
SickSC3
SickSC3's Avatar
your drag set up looks so sick!! i would love to see #'s
Old 01-04-13, 09:43 AM
  #51
RudysSC
RudysSC's Avatar
Received 1,197 Likes on 830 Posts
That thing looks so, so nasty on the drag set up. Jesus Christ. Too cool man.
Old 01-04-13, 01:34 PM
  #52
preston145
preston145's Avatar
Thanks buddy I'm hoping she will be a handful. She was pretty hard to handle with how bad the Control arm bushings being as wore out I had like a 1/2 in ch of play on each lowercontrol arm, I just finished replacing the entire suspension. So hopefully no wheel hop for me, i havent even driven it yet as I'm waiting on my turbo to come in, I hope she feels liek a new car with al the new poly in her. Here's some more pics of the process.
Heres a before
Here's and after
Thanks man i apprecisate it so much, I hate to driving it on the street like that because it takes away from the suprise that it actually moves out fairly well lol
Thank you sir!
Old 01-04-13, 02:46 PM
  #53
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
How did the Harbor Freight tool work out ocmpared to other brands? It looked like it did the job without any issues.. Your wheel hop should prolly be gone for good for now.
Old 01-04-13, 03:17 PM
  #54
preston145
preston145's Avatar
Worked out great no issues what so ever, Of course the lowers i had to torch out which again was quite simple. But im stoked to drive her!
Old 01-04-13, 08:33 PM
  #55
LEXXIUM
LEXXIUM's Avatar
Is r154 can even hold that much hp? I thought it was good till about mid 600ish, after that its a ticking time bomb?
It would have to be some upgraded internal parts or something and a clutch etc it even comes to that kind of power.. Am I wrong?
GISguy
Performance & Maintenance
20
01-29-23 10:57 PM
Zinik
SC400 / 300 Classifieds
03-08-13 01:02 PM
jwin
09-03-12 10:01 PM
charley240
13
08-07-12 02:23 PM
Quick Reply: Fastest r154 sc300? Pics of my setup.
