Passenger fog light not working..
I've searched and searched and searched on what could be the problem. But have come up with nothing. I have. 1997 sc 5 speed and I just picked it up 2 weeks ago. No major problems besides the bleeding climate control which I've found to be common. The only annoyance is the passenger fog light won't turn on for anything. I changed the bulb even though the previous looked fine and still does not work. Checked all the fuses and they're all okay.. Any suggestions would be much appreciated. I am new to the forum as well as the car.
i have the same year but auto im in tx so it almost impossible to find a 5speed
but i have the same problem'
what i am going to do is change the driver to passager and see if its just the wire thats bad and go from there'
let me know if you find out whats the problem'
thanks and good luck'
Same problem but I have a 95 converted to a 97+ front end. I found that the OEM "housing" doesn't hold H3 connections very well. I should mention that I went to HID's in my fogs, but I had the same problems with normal bulbs in the past. I tried something which worked ok for a month. I wrapped the ends of both H3 connection cables with aluminum foil to make a tighter fit. You can probably use other methods but it is a conductive material. When everything was connected I tested everything and it worked just fine. I then wrapped everything with tons of electrical tape and tried a few shake tests. It worked just fine for a month or two until I nailed a ton of pot holes in our nationals capitol. I took everything apart and tried it again but nothing seemed to work. I'm think I blew the fuse in the ballast or something which sucks because I zip tied it to the bumper support :facepalm:
same problem here... i tested the wires and it seemed for me that the paperclip like metal wire on the housing has jus corroded and lost its conductivity since i was getting power up to that point.....i was jus gonna buy new ones evantually instead of trying to rig it
