SC- 1st Gen (1992-2000)
advice on replacing o2 sensor
Old 08-15-11, 09:50 AM
Mr1uz
Mr1uz's Avatar
Originally Posted by sc300jz
Check out amazon, they had some for the sc300 for only $50 vs 100's everywhere else
Thanks for that info. Will check. I did find one on RockAuto.com for $33.79.
Its a DENSO Universal OXYGEN SENSOR, Part # 2344209.
Old 08-15-11, 11:22 AM
boostin240
boostin240's Avatar
Dont get a universal O2 for a OBDII car. They dont last as long as the OEM replacement units. Also DENSO is OEM. DENSO makes half the parts on every Toyota and Lexus. Going with universal 02s is only a good choice if you have OBDI and a single wire 02. Bosch will work as well or NTK ( division of NGK ). But best bet is Denso for longest life and best performance.
Old 08-15-11, 11:31 AM
abounly
abounly's Avatar
Yeah i didn't go with the universal one. Occasionally people on CL will sell new O2 sensors. I was able to scoop one up from CL.
Old 08-15-11, 01:03 PM
Mr1uz
Mr1uz's Avatar
Thanks! You guys are the BEST! Saved me from making a bad purchase! I will NOT get the universal one than! I will buy strictly OEM.
Old 08-15-11, 04:27 PM
blacksc4
blacksc4's Avatar
im doing my o2's soon too and was looking at the bosch universals, but y is it different to be ok with obd1 and not obdII? im obdI tho so i guess im still good haha but isnt it a 4 wire o2?
Old 08-15-11, 11:40 PM
boostin240
boostin240's Avatar
OBDI should be a single wire. OBDII has a 4 wire as its a heated 02 sensor. Single wire sensors operate on a less complicated principle, only 1 wire vs. 4 wires, the 4 wire heated sensors have a heater circuit which helps to warm up the sensor to operating temperature so that it can read properly much faster. 02 sensors generate a voltage that the ECU translates into the air/fuel ratio which in term tells it how much fuel to inject, how much timing to run etc.
Using a universal 4 wire sensor also increases chances of mixing the wiring and causing all sorts of electrical issues. On a single wire 02, you cant mess it up since its just a single wire. Also application specific sensors tend to last longer and seem to be more precise in giving the ECU a proper reading AKA car will run better / smoother. I have used several universal single wire 02s on older Nissans and on my own SC300 and so far no problems. However serveral of the universal 4 wire sensors that I have dealt with gave me all sorts of issues both on start up and after a period of time. It all really depends on the vehicle, but certain cars tend to be picky with the parts that you put on them.
Old 08-16-11, 12:08 AM
blacksc4
blacksc4's Avatar
thnx i thot the older obdI sc400 had a 4 wire upstream, i havnt looked at mine yet but tht was my understanding, im gonna gove the universals a shot ill see how it goes
MsbTTSupra
02-21-20 07:27 PM
PrisyCrisy
IS - 1st Gen (2001-2005)
03-21-19 01:16 PM
Rolodon
01-20-19 02:59 PM
jwigley
RX - 1st Gen (1999-2003)
10-13-15 09:54 AM
Hit Man X
07-15-05 06:54 PM
Quick Reply: advice on replacing o2 sensor
