my sc400 hydraulics fan went bad help??????
Old 03-03-11, 07:10 AM
djshadow
djshadow's Avatar
Default my sc400 hydraulics fan went bad help??????
my hydraulic fan went bad and want to go electric is there a post of some one doing the swap or conversion or some one tell me what would i do with the oil lines please.... cause my car over heat cause this dumb *** fan heeeeeeeelp
Old 03-03-11, 07:50 AM
CSSC400STL
CSSC400STL's Avatar
I don't think you can swap it out. I tried that and it just made things worse than what they was. is it just over heating or are you snapping belts in the process I had this problem with mine I just replace the fan pump pulley than my car was fine
Old 03-03-11, 10:56 AM
vegas_sc4
vegas_sc4's Avatar
Jus get a shorter belt and skip the hydro fan pulley. I did it on mine and worked fine
Old 11-26-16, 06:46 PM
Skeech
Skeech's Avatar
Do you have a part number for that, or the length of the replacement belt? I'm looking at deleting my hydraulic fan as well. Thanks.
Old 11-28-16, 01:21 PM
vipsoarer
vipsoarer's Avatar
Dont delete your hydro fan unless you decide to get an ls400 idler to replace it and even then just use a stock sized belt. All I did was loop my hydro lines into the reservoir since my pump was shot and only worked on low speed and am replacing the motor in the spring. I replaced the hydro fan with IS300 electric fans and haven't had an issue yet.
Skeech (01-16-17)
Old 01-16-17, 06:17 PM
Skeech
Skeech's Avatar
Thanks for the replies everyone. I'm in process of the timing belt, water pump, and cam/crankshaft seals, and of course temperature sensors. My hydro fan spun quite slow if at all, and the fluid smelled burnt. My SC has 155k on it, I got it from a guy who had not worked on it himself and I'm just doing every service I can find on it, belts, sensors and tuneup. (All filters also.) Water pump started leaking so I'm going for it. I've seen a few electric fans and shrouds, they are 16" and the stock one is 18"... so... I'm looking for an electric motor I can mount on the stock fan and shroud. Any suggestions? If that doesn't work I'll just go with a kit.
Moarpower
24
07-23-18 06:11 PM
bigjussin
11-11-12 12:28 PM
xknowonex
06-15-05 09:35 AM
gompka
GS - 1st Gen (1993-1997)
09-28-02 02:00 AM
Quick Reply: my sc400 hydraulics fan went bad help??????
