1.5jz-ge+t questions !!
ok soo im in peru and they closed the importation of all used engines to the country soo i cant swap in a 2jz-gte, the only 2 options i have, is buy a 1jz-gte(which i can obtain) swap it in or do the 1.5jz swap onto the ge block, if i do this i would be puting in forged gte piston, a few questions
1. what do you guys suggest 1.5jz-gte, or just swap in the 1jz
2 if i do the head swap i should probably use a 1jz ecu until i get my haltech ps2k
3 also my car is an auto ill be using the r154 from a mk3 i wanted to know will the sc300 auto drive shaft fit the mk3 r154?
thats pretty much it any help or opinions are more then welcome
Regan Jackson
Regan Jackson
SuicidnS13
SC- 1st Gen (1992-2000)
36
07-12-10 07:12 PM
