SC- 1st Gen (1992-2000)
Will an obd1 sc300 body harness plug into an obd1 sc400?
Old 02-22-11, 02:49 PM
sebasc300
sebasc300's Avatar
Default Will an obd1 sc300 body harness plug into an obd1 sc400?
Or will the body plugs have to be repinned?
Please don't ask me why I want t swap a 2jzge into my sc400.
Lets keep this thread on track.
Thanks in advance Guy's.
Old 02-22-11, 07:50 PM
2low2go
2low2go's Avatar
Simple answer...no. Can you cut and splice? Yes. Much easier option to replace the harness with the correct one.
Old 02-22-11, 08:53 PM
sebasc300
sebasc300's Avatar
OK so the body plugs are a different shape?
Yes I can cut wires And solder no problem.
What do you mean replace the harness with the correct one?
Old 02-23-11, 08:44 AM
99SC42
99SC42's Avatar
It's almost PNP, you just have to move 1 or 2 wires to the next pin.
I had 2jzna-t in my SC400 and the only issue you will have the 12V fuel pump mod ... do not do that mod on your car and you will be fine.
And you just have to jump a couple of power wires to feed the others it took me 2min to do and worked great.
Old 02-23-11, 09:50 AM
sebasc300
sebasc300's Avatar
Thanks for clarifying things.
By any chance do you remember what pins had to be moved?
Thanks in advance.
Old 06-25-12, 08:33 AM
OBEEWON
OBEEWON's Avatar
An answer to that would have been awesome!
Old 06-25-12, 09:35 AM
99SC42
99SC42's Avatar
Your ignitor will not power ON until you jump the wires in the passenger side kick panel .
Check those orange with black strips wires in the kick panel (body plugs ) they are on the grey connector that comes from the engine harness and plugs to the passenger side kick panel.
if you can post some pics of your body plugs , i will tell you which one goes where and what needs what!
92sc400dd
Performance & Maintenance
02-24-13 09:20 AM
supra925
SC400 / 300 Classifieds
11-19-12 07:04 PM
xspsi6
08-26-11 01:32 PM
red87tll
05-20-11 08:04 AM
ef0cmacro
07-23-08 04:01 AM
Quick Reply: Will an obd1 sc300 body harness plug into an obd1 sc400?
