SC- 1st Gen (1992-2000)
W58 Transmission Question
Old 12-24-10, 04:29 AM
Confusion
Confusion's Avatar
Default W58 Transmission Question
Just wondering if a W58 out of a Mk3 will fit right into a 93 sc300? If not what else would I need to purchase to swap this transmission from a auto? and if a 1jz swap would be easier and better?
Old 12-24-10, 06:35 AM
SC YAA
SC YAA's Avatar
Um i would think so the only part that confuses me is the bell housing. like in a r154 i know you need the 1jz bell housing but i think and dont shoot me if im wring but on the w58 i think you would need the 2jz bell housing.
Old 12-24-10, 11:48 AM
Sc4Jr24
Sc4Jr24's Avatar
I believe you would have to extend the shifter and there not as strong
Old 12-24-10, 01:19 PM
nine3es
nine3es's Avatar
what about from an 89 supra?
Old 12-24-10, 03:25 PM
nivek5sfe
nivek5sfe's Avatar
from what i remember i think you need the tail section and bellhousing off of a later w58 to make it fit. also the correct driveshaft.
Old 12-24-10, 06:32 PM
megamax
megamax's Avatar
ive mulled over this thinking saving some coin. But at the end of the day you are better off just getting a 1jz motorset complete...
Old 12-25-10, 08:47 AM
JakeBreyck
JakeBreyck's Avatar
Don't simplify information this breeds misinformation. 89 and up W58s are steel center section, like the sc300 and mkiv W58, strength wise they are the same. Quite possibly as strong as a R154, (i say this because i can break a R but for the life of me cant get a W58 to fail) Pre 89 W58s have an aluminum center plate, and they are known to fail around the 300hp range when abused. and this is where the internet Misinformation came from about the W58s being weak.
the shifter on the mk3 transmissions is shorter, we put a mk3 transmission in bardledoo's(sp) sc400, and i made a S shaped shifter to make it reach the SC shifter hole. the drive shaft works the same. changing the tail section of the transmission if you have one handy will work as well. and of corse you'll need the bell housing.
Old 12-25-10, 09:41 AM
RedPhoenix
RedPhoenix's Avatar
Also a custom mount will be needed. Just get the right transmission... 92+ SC300 or 93.5+ Supra.
Old 12-25-10, 12:37 PM
BartleDoo
BartleDoo's Avatar
Speaking of which, I think I'm gonna try again with a stock shifter because the non-dampened shifter vibrates too damn much and I want to use my TRD ****.
Old 12-25-10, 12:51 PM
JakeBreyck
JakeBreyck's Avatar
ok let me know if you need anything welded kevin.
Old 12-25-10, 03:46 PM
sc400LEXO
sc400LEXO's Avatar
driftmotion sells a 1 piece w58/r154 aluminum or steel driveshaft also optional metal doughnut instead of rubber isolators between the driveshaft. Problem solved.
Old 12-25-10, 04:25 PM
BartleDoo
BartleDoo's Avatar
Yea and I'll come hang out and put in my 400lb rear springs at the shop while you work on the roadster this week.
Old 12-25-10, 04:58 PM
RedPhoenix
RedPhoenix's Avatar
And my Supra
Old 12-25-10, 05:48 PM
JakeBreyck
JakeBreyck's Avatar
new springs? nice, ya i have some plans for the roadster this week. somehow this turned into our personal chat thread. Sorry OP.
Old 12-25-10, 08:15 PM
LEXXIUM
LEXXIUM's Avatar
I thought 350 was stiff enought(In the garage ready to go in any warm day), but 400?. Are you plannin on drifting Bartledo?
Hey man, the topic has been beat to death lol, op can find his answers twice on this forum and then some
Quick Reply: W58 Transmission Question
