So our cars are freakin tanks, need oil pan diagrams
Last night it was pouring raining, black *** roads, and I thought I had turned into the turning lane of an intersection, but it ended up being a U turn lane. I was slowing turning into the lane and I noticed there was a cement median. Unfortunately my first thought was there was there shouldn't be a median there, then i ran the median over with the drivers side of the car
I knew my front tire was gone instantly the rears questionable. Everything else seemed bad at the time. I pulled over to the gas station next to the turning lane. Got out of my car and saw freakin oil leaking under. Turned the car off instantly. The leak stopped after I turned the car off.
Left the car at the gas station allday and got towed it back with the F250 and my cousins car trailer
Got home, lifted all four wheels on jackstands and discovered this
The car survive it, no damage to the motor mounts, engine, transmission, transmission mounts, cv axles, radiator, front bumper nothing, I was amazed. The car still drives just leaks oil,
The gasket to the oil pan collapsed under pressure and the upper oil pan cracked a lil. Other than the obvious rim damage that was it. This car is freakin sturdy as hell. Of course I haven't removed the oil pan yet to check the real damage, which ill do after finals.
A chunk of metal was actually ripped from idk what that is really
The ATB? oil pan gasket pretty much collapse or got squshed under the pressure
The upper pan has a small hairline crack in it
unfortunately my bent rims
How my car sat before the accident
Plans on fixng?
*take the oil pan out, check it up and down
*weld the upper pan if I can
*change out the gasket
*bolt the pan back on and hope is doesnt leak anywhere else.
*change out my springs in my coilovers from supra tts, to hypercoils,
*the car will be garaged and worked on for the winter, so losts of things if money allows
*2uz bottom end maybe?
I do need a diagram to the upper and lower oil pans on a 95 sc400
Plans on fixng?
Glad to see that there was no bodily injury. Sucks for the rims though. I know the feeling.... But that chunk that seems to be missing looks like it could be part of the subframe got a piece taken out of it. I had the same exact looking missing chunk when my car hit a Huge hidden pot hole while driving in the rain... Get it checks and its not that hard to change out if you get a decent one from a junk yard.
GL man.
GL man.
ouch!!! I had that same thing happen to me 2 months ago but I didnt mess up ma oil pan.
I hit one going 45mph, someone cut me off and i cracked and busted my front rim and tire and bust up my rear tire.
looks like your not the only one who has made the mistake.... maybe you should ask the city for some help on repairs....
if the "engineering" has not been assessed in awhile you might have a chance...wont get a check overnight, but might be worth looking into...
rena
02-14-14 12:08 PM
SickES350
CL of Southern California
36
06-30-09 01:38 PM
