SC- 1st Gen (1992-2000)
1jz running rich after single conversion at first start up
Old 10-04-10, 08:39 PM
Cletus
Cletus's Avatar
Default 1jz running rich after single conversion at first start up
So i recently did a single conversion on my 1jz and now it runs like ***** until it gets to operating temperature. My wideband shows it running at like 20 afr for probably the first 2-3 minutes of driving. Its almost like the ecu has to reprogram the tps every time i first start driving. It bogs and sputters up to about 50% throttle and after i get past 50% it runs like a champ and no problems till the next time i shut it off. Do you need a different map sensor that reads lower vaccum and higher boost after a single conversion? Is this dangerous for the engine running that lean at low rpm (no more than 2500-3000) for a minute or two, i make sure to not run higher until it resolves? thanks in advance.
Old 10-06-10, 11:25 AM
ProjectSC3
ProjectSC3's Avatar
Well running that lean can mess up your internals and cats if you have any. Have you gotten your car tuned sence you change to a single turbo?
kennymahr
Performance & Maintenance
12-07-16 09:39 AM
WetLexus
04-10-11 03:08 PM
turbodremz
12
10-28-10 07:48 PM
Yahoo27
07-30-09 10:45 PM
Quick Reply: 1jz running rich after single conversion at first start up
