SC- 1st Gen (1992-2000)
I Wanna Relocate Battery To Trunk ?
Old 01-13-12, 10:56 PM
  #61
scviolence
scviolence's Avatar
Originally Posted by MKIVS374
scviolence by the way sick valve cover nice work.
Thanks bro appreciate it
Old 01-14-12, 06:24 PM
  #62
BenStoked
BenStoked's Avatar
I you don't know from what has been written so far the. You might be endangering your car even more. I know you guys wanna ask questions but all it is is cutting undoing the batt terminals adding a splice for the #2 wire to the trunk strap it down and put batt terminals on that put Bart in box and done. This is rediculus really people. Take your car to a shop and let someon Sauk knows what there doing do it if you can't understand simple instructions.
COME ON I KNOW SOMEONE WANTS TO CALL ME AN ******* SO LET'S HAVE IT.
there is a ltiitle more than that.
It's more like wiring an amp than you describe.
but, yeah, I've installed acouple, and I know how easy it really is. it's the little things that deserve attention (where to run the lines, what spot's best to drill., why you use a grommet, etc. etc.)
but you did come across as (insert whatever asterisk masked word you meant) in the last few posts.
Old 01-14-12, 07:29 PM
  #63
CrispyST3
CrispyST3's Avatar
U don't need a long wire for the ground because they are grounded to the chasis
Old 01-14-12, 08:08 PM
  #64
MKIVS374
MKIVS374's Avatar
I know but some people on here just don get it nothing against you either but just I you don't understand stuff like this then take it to a shop cause it's pretty simple. Just don't wanna see them mess there cars up or hurt themselves.
Old 01-17-12, 01:19 AM
  #65
rtm18990
rtm18990's Avatar
Old 01-17-12, 10:02 PM
  #66
WadeLovell
WadeLovell's Avatar
This seems like a good DIY project. Look at any decent boat installation for ideas about securing and protecting the battery and cables as well as cut offs, shut offs, and overcurrent protection.
Old 03-18-13, 06:02 PM
  #67
grumpi300
grumpi300's Avatar
dang, i'm bringing up a thread from the grave. i mean almost a half decade ago old. haha.
anyways, i just wanted to verify im gonna do it right.
when 1siksc said 4 wires, i'm thinking its 1 for ground, 3 for positive. one to alternator, one to starter, and one to fusebox. i just a picture to show how it would be. is this right? or am i wrong?
Old 03-18-13, 08:32 PM
  #68
estomax
estomax's Avatar
You are way over doing it man.. if you get one 2 gauge wire running from the stock battery + location up front to the battery in the back, and a short ground wire from the battery to the chassis, and ground the stock - to the chassis in the front of the car, you will be fine. Me and a million others have done it this way with no issues. If you want to add the weight of a ton of wire though, go right ahead. just make sure to scratch the paint off of wherever you put your big ground lugs. For safety you can add a 250 amp inline fuse at the battery (should be sufficient so the starter doesn't blow it), so if the new battery + wire somehow shorts out due to an insulation rub somewhere in the run through your car, then you won't burn it down. If you have three wires running to the battery, then maybe put three fuses.. lol.
GR1MRPR
Performance & Maintenance
01-11-12 05:27 AM
ToyotaLexus
02-12-09 01:24 PM
dumdumgreg
12
03-29-06 01:33 PM
dkny_112
09-12-04 11:34 AM
VSsc400
07-13-04 10:11 AM
Quick Reply: I Wanna Relocate Battery To Trunk ?
