Last Thread Radio Help
Hi all im sure you all are tired of my radio help threads since April iv been making haha...Since then I have replaced the radio, and the amp trying to get my audio system to work. Today I got my amp (Thanks so much Balconelly) and plugged it in. I got rid of the do do do do do sound and could hear reception but it was all fuzzed out.
My antenna is up and 99.9 it works properly. When I seek stations it just keeps going cause no stations come up. I did one time when manually doing it get 1 station to play on FM... My Zune hookup works I set it to 88.9 and can play fine. But why can't I hit the rest of the stations. I figured it wasn't incorrectly connected since I did get 1 station manually but it doesn't find anything while seeking for preset stations.
Long story short is it wired wrong in a way I can listen to my zune hookup but cant get the stations?
maybe the antenna power is hooked up so it's going up and down, but it's not hooked to the radio properly so all you're really running off of is the wire leading to the antenna. That would explain you being able to use the zune and then not getting the range for any other stations that are further than 10 feet haha.
Then again, I'm just speculating
TheLexor
11-04-07 04:49 PM
