hazard lights work but turn signals dont ?
Registered User
Hello,
I recently put in new headlights. Everything worked fine until I was messing with one of the turn signal bulb's wiring. Now none of the turn signals work in the front or back, the signals dont even light up on the cluster. When I press the hazards though, the turn signal bulbs light fine. What could cause this?
This might not be realted to your headlight or bulb replacement at all. Saying that the bulbs work with the hazards your mutifuntion switch could be the culprit. If it is not making a connection threw the switch and only the hazrds that sounds like the problem. Did you use the same model bulbs by chance? Were they single or dual filamet bulbs? Not sure if there are 2 separate circuits for the lights ,but check the fuses to make sure they did not blow out.
i once installed some lame altezzas on a integra back in my ricer days, it stopped the blinkers from working but hte hazards worked, put the old tails back on and they started to work again, dunno what it was but something to do with the bulbs
