I have several electrical issues, would you like to help me?
today was was running some earns for my moms when i stoped at super market the power locks and tilt wheel failed. also my power windows too have failed so i left on my way back home i hit to pot holes and it felt like the car. i leave to go bac out to cash my check and now the shifter is stuck in park just wanted to turn off i have pulled both the driverside wheel and checked the harness is seems fine it has a lil rub from the tires but i still have that plastic piece to cover the harness nothing seems torn on the driver side im on my way out to look at my pass side now
1) the shifter is stuck in park
2)my windows or sun roof is open and exposed
3) my tilt wheel and power locks are fried
Keeper of the light
You wouldn't believe what a simple attempt to title a thread would do for your help. Ask anyone here, "help!" is the commonly most ignored thread title on the site. (We've done a poll)
Andrew already gave you the correct answer.
Keeper of the light
Not saying you didn't check them properly and all that, but the last 5 guys we told to check fuses and they said they were good came back a week later saying "aw hell that one LOOKED good, but I replaced it and it worked after that". which is why I never inspect fuses by sight. Incase you didn't, use a test light or voltmeter and verify current capability across the fuses. It makes a world of difference in waiting a week or more if you really do have a bad fuse with a junction breach.
Also, check outside, under the hood on the higher power stuff since this is a main junction somewhere you are having issues with.
From there, Have to start at the source (main junction box) and work backwards.
Good luck!
Good luck!
I had the same problem when the battery died. I believe the ignition lock and shifter lock are tied together in some fashion. I say check battery and alternator.
The window thing, not sure what to tell you there.... I've had the same issue but it was a ground wire gone bad in the wire harness which is common....
Hope this helps.
Hope this helps.
