How to install 97 side skirts?
#47
Does anyone know what part number I use to get the white screw looking clips (there are five) that go into the side of the body to attach to where i removed the pre 97 moldings. Im looking for the clips that you hook inside of the actual side skirt. On my passenger side they were a yellowish white. I went to the dealer and bought the part #75494 from looking at the diagram thinking it was the correct part. Wrong!! I made a $20 mistake. This is the last piece to my 97+ conversion and I cant seem to get the part number. Help to the rescue.
thanks in advance
#49
OK guys, here's my questions.
I don't have any holes on my undercarriage for #1 to go into...
Does anyone know the correct name/part number of the clip that goes onto #2?
Are my correct to assume that the clips that go into #2 push into holes in #3?
On a pre-97 model #4 is a bolt, which obviously doesn't work anymore. Does anyone know the clip (which would be the same as the clips in #3) part number? To make it easier, does anyone KNOW, not guess, which parts I am looking for on this list?
Thank you very much
Jonny
Thank you very much
Jonny
#51
Check this website out.
http://www.clipsandfasteners.com/Toy...eners_s/13.htm
It has Lexus and Toyota part number cross- reference with pictures and dimension.
6 pages. Should be able to find what is needed to complete the installation.
And you also need to saw away part of the wheel well retaining plates at the bottom for all 4 plates. There is a line there to saw. Or else the side skirts will not sit flush at the wheel well area. Then align them to and drill the holes at the skirt for the screws to the fender.
Just finished my installation
#52
Sorry to bump this, but this is the thread with all the info with pics, so I guess it doesn't hurt.
The moulding on the LEFT comes off permanently right?
The door I guess stays there unless I have the 97+ door mouldings?
This is the Shine Auto AC side skirt.
Do I cut off the rolled lip where it is supposed to be attached to the body where the moulding used to be?
For clarification purposes. Thanks!
#54
FYI, if you remove these grommets, some of the holes line up with the skirt holes. you can use these push clips to attach them. i believe 3 on each side.
https://www.ebay.com/itm/132419930072
