SC- 1st Gen (1992-2000)
Old 12-12-14, 04:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
Print Wikipost
****Official Wheel & Tire Fitment Guide for SC300/SC400****
Old 01-31-07, 10:18 PM
  #796
G Star
G Star's Avatar
Originally Posted by henry1
19x8.5, 19x9.5 Volk LE37
Offset is +29,+34
Tire size is 255/35/19, 275/35/19
will i need to roll fenders? are front tires too wide?
how is anybody supposed to answer your question if you don't mention how much you wanted to lower your car?
anyways, if you want limited gappage you're gonna have to roll for sure and yes the front are a little wide but you should be ok. ROLL IT
Old 02-01-07, 06:24 AM
  #797
Kohinoor
Kohinoor's Avatar
Originally Posted by chanh55
Hello wheel fitment gods...
Can you tell me what size and offeset wheels Ueno is running on his Vertex Ridge Soarer as pictured here:
http://saikomag.com/Cars/D16D0F90-BA...66F0E0BDF.html
Thanks in advance.
19x9.5 -9 245/35/19
19x10.5 -15 275/30/19
you can do lower offsets if you choose to go with skinnier tires
Old 02-01-07, 07:54 PM
  #798
Toshima
Toshima's Avatar
Is there any way to put F=18x11 with -1m, and R=18x13 with -15 on a sc300 with out buying a widebody kit? Anyway to make them really close to flush with a pulled fender?
Old 02-02-07, 06:23 AM
  #799
BLK13X
Mortgage Slave
BLK13X's Avatar
Have fun fitting those on mate.
Old 02-02-07, 06:40 AM
  #800
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
Originally Posted by HoeBag
19x9.5 -9 245/35/19
lets all keep in mind that that car has a widebody kit and that there is no way in hell those would fit on a stock bodied SC without a lift kit or fender removal...
Old 02-02-07, 06:46 AM
  #801
mitsuguy
mitsuguy's Avatar
There isn't room underneath the car for that wide of a wheel If there was just by chance, you would have to run a much higher offset...
Here's an example - my wheels are +35mm offset, 9.5" wide - they sit very close to flush with the rear fender... they sit 92mm out from the hub, so, reasonable to say, a wheel with 90-100mm front side depth (not a technical term, but meaning from the hub of the vehicle to the face of the wheel) is flush with the rear fenders... the face of those 18x13's would sit 193mm from the hub, a whopping 4 inches out farther than mine - the positive side is that that wheel would work in terms of inner suspension clearance just fine...
Old 02-02-07, 06:53 AM
  #802
Jacj3
Jacj3's Avatar
I'm gettin some wheels from CCW SP500s 18x8.5f and 18x11r what would be a good tire size to run.
Old 02-02-07, 07:33 AM
  #803
mitsuguy
mitsuguy's Avatar
What offsets?
Rolled Fenders (or plan to)?
We would need that stuff first...
Old 02-02-07, 07:39 AM
  #804
mitsuguy
mitsuguy's Avatar
Offset is +29,+34
Originally Posted by BLK13X
Front and rear tyres are too wide if you're going to have it lowered a heap... maximum I'd go, say around 235/35 front and 265/30 rear or 245/35 rears.
No, those widths will be fine, the heights won't though - both of those tires are about an inch too tall... I run 275/30-19 on 19x9.5 +35mm offset, and no rubbing with rolled fenders...
Lowered or not has almost nothing to do with wheel fitment / clearance - if a wheel doesn't rub at normal ride height, but rubs when lowered, then all that means is that at normal ride height if you hit a bump, it will rub - lowering just uses up part of your available suspension travel...
Old 02-02-07, 12:05 PM
  #805
AME_VIP
AME_VIP's Avatar
you will need vertex ridge or other true widebody kit.
pull will not be enough
Old 02-02-07, 02:01 PM
  #806
roo
roo's Avatar
Amen to that!
Old 02-02-07, 02:03 PM
  #807
Kohinoor
Kohinoor's Avatar
anyone know where i can find 19x9 +20 19x10 +0 offset wheels, or something similar.. im having quite a bit of trouble
Old 02-02-07, 06:19 PM
  #808
BLK13X
Mortgage Slave
BLK13X's Avatar
I'm no wheel expert but I can tell you from what I'm experiencing currently with my car is scrubbing at full lock at the height it sits at now (dropped 2" up front, 1.25" rear... scrubs either way, though usually when negating a right hand turn and will scrub the left side guard lining) but it'd never scrub at normal height. That's on 235/40/18's and only going by my experiences on a +40ish mm offset. My old Soarer (18x8.5"/+38mm, 235/40/18 fronts, dropped about 2.5") never scrubbed the front guards whatsoever, and the way the car was aligned to cater for the drop virtually prohibited any outer guard lining scrubbing. Remember, I'm only referring to the car when it's wheels are locked, not driving straight (usually it's fine driving straight unless I crash throught an ungodly behemoth pothole).
Old 02-02-07, 08:34 PM
  #809
Toshima
Toshima's Avatar
So could I get away with some 18x9.5 +18 18x10.5 +18 with just a roll, and pulled?
Old 02-02-07, 09:08 PM
  #810
mitsuguy
mitsuguy's Avatar
the difference is that when you hit a moderate bump with it lowered, it gets into that "rubs the inside" area, whereas with it at stock height you would have to hit a much more aggressive bump to get it to rub...
whats weird about your car, is I have 255/35-18's on a +40 mm offset, and the only time mine rubs is at full lock and going through the dip turning onto my street faster than 25 mph - no other time, ever have I gotten the front to rub...
Quick Reply: ****Official Wheel & Tire Fitment Guide for SC300/SC400****
