Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
- IS ES GS: Lowering Modifications
Important information to help you understand your Lexus
- How to Mount a Tire to your Rim
Step by step instructions for do-it-yourself repairs
- Tires General Information and Specs
****Official Wheel & Tire Fitment Guide for SC300/SC400****
#5701
Decided to go with 295/40/18 in the rear and 245/40/18 in the front I was worried about the rear panel, just a light roll of the fender and And it fit great. I was surprised how it change the look of the car.
#5702
Former Sponsor
Evo X GSR Enkeis 18X8.5 +38 offset. 22lbs a wheel, and i had them from previous DSM builds. Stock suspesnsion, will update when i install coilovers:
I'm actually pretty happy with the fitment (minus the massive wheel gap), the weight isn't terrible, and i got them for 200 bucks originally so...
#5705
i have a chance to buy a set of Is250 rims for $200. i looked up the offset and its +50 the same as the sunken factory wheels. does the fact that they are 8.5 in wide make a diffrence? Is there anyone who has had these rims on their SC? Should i getthem or keep lookin?
#5706
Fitment help
Hi guys it seems that this thread will be a life for ever, many thanks newyorksc who started it.
I'm going for some very basic fitment, Lenso D2R 18*8 / ET +38, thinking about 245/40/18 tires to avoid big speedometer wrong readings, and I'm Megans coil-overs, as per this thread everything will be fine with no issues.
.... I will be happy to see some pictures for the same set up if somebody has it the same.
many thanks in advance.
#5707
Work Euroline Dh
18x8f +25 on 215/35r18 with a 38mm spacer (I know I'll shoot my eye out...)
18x9r +31 on 225/35r18 with a 20mm spacer
and my old set up
Sparco ns06 (feather light wheels.. could almost lift them with 1 finger even with tires)
18x9.5 +22 all the way around. Can't remember tire size
#5709
hmmm... with the pull you might get away with it, but it's gonna be tight. more than likely you'll need more stretch and probably some extra camber.
edit: front's will fit with a little stretch just fine on a soft roll like mine.
#5710
should have went with 295/35, since that 40 profile you have is too much for this car and those wheels
#5715
need help!!! goin for a new set
19x9.5 +22 fronts 245/35/19
19x11 +22 rear 265/35/19 w/camber kit upper control arm
going for a flush look for my car also fenders and rear quarters are rolled
w/ max coilovers
direct fitment??
swapping rear new tires for the new to the fronts
w/ max coilovers
direct fitment??
