SC- 1st Gen (1992-2000)
Old 12-12-14, 04:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
Print Wikipost
****Official Wheel & Tire Fitment Guide for SC300/SC400****
Old 03-14-16, 12:25 PM
  #5671
jwynn
jwynn's Avatar
Default Anyone know what wheels these are?
Can someone tell me what these wheels are?
Old 03-14-16, 03:13 PM
  #5672
Oaklandsc3
Oaklandsc3's Avatar
Would I have to pull rear fenders to put on style 95s rims which are 19x10 +24 with 15mm adapters?
Old 03-18-16, 10:38 AM
  #5673
jwynn
jwynn's Avatar
Default ?
Originally Posted by RaynArt
not only too thin but tc's are 5x100
on that note quick question. have a friend who may sell his wheels, need opinions on this size.
18x9 +12
18x10 +12
my fenders are rolled. will those poke out too much? im sure id have to stretch a tire a bit
DID you ever get this set up? Searching the threads this is closest thing i found to what I'm trying to run currently. If u have any pics that'd be great.
Old 03-20-16, 10:10 PM
  #5674
Deegee
Deegee's Avatar
18x11.5 +43 and 18x11.5 +47
My car has vertex rear over fenders, stock front fenders
Has roll and pull.
Im more concerned if these wheels will interfere with my suspension components without spacers.. stupid high offsets and width.
Old 03-21-16, 01:09 AM
  #5675
PaCowboy
PaCowboy's Avatar
Looks like SSR professor sp3
Old 03-21-16, 12:42 PM
  #5676
Blkexcoupe
Blkexcoupe's Avatar
Has roll and pull.
The rears will be ok with coilovers (some hammering might be involved). I think it could potentially hit a spring and shock combo or air suspension.
I'm not sure about suspension clearance in the front. I can't think of any cars that have wheels that wide in the front. If the wheels are 3 piece, then you could probably find the inner barrels used and swap them out to make a narrower wheel while maintaining the same lip on the outside.
Old 03-23-16, 02:28 PM
  #5677
Deegee
Deegee's Avatar
Now that I'm thinking about it... I replaced the 4 lips not the barrels, so I think these will fit on the inside without any problems, they just may poke out a bit in the front.
More importantly, what tire size should I go with on these??
Old 03-23-16, 09:28 PM
  #5678
sunny416
sunny416's Avatar
CL Member Name: Sunny416
Rim Brand and Type: Kranze Cerebus 3
Rim Size f/r: 18x10.5 18x11.5
Rim Offset f/r: +18 and +13
Tire Size f/r: 225/35 and 245/35
Suspension Setup: Megan Street (Fortune auto awaiting install )
Comment On Ride: Soft
Fender Modifications: All 4 are Rolled and Pulled
Any other comments: Must remove harness (just do it. dont think twice about it)
Picture:
Attached Thumbnails ****Official Wheel & Tire Fitment Guide for SC300/SC400****-thumb_20151026_183347_1024.jpg
rishard97 (07-29-19)
Old 03-24-16, 06:45 AM
  #5679
jwynn
jwynn's Avatar
Default Hows this set up?
Trying to figure out if this set up will be a good one. Ive found a craigslist guy selling Euro Mag Wheels ( Any experience with this brand feel free to tell me) and potenza tires from his mustang. He's running 275/40 tires on 19x9.5 +40 Em10 wheels all the way around. Will this be sunken in
? and if so what spacer would I need for a flushed look my car will be lowered 2-3inches soon so if there would any interference with suspension components please let me know but I truly doubt there would. If anyones got any similar set ups post pics please. Haven't found this exact set up yet in the forums but still looking.
Old 03-24-16, 09:56 AM
  #5680
Blkexcoupe
Blkexcoupe's Avatar
The inner clearance doesn't change at all unless you milled the backing down.
Your offsets are still very conservative for a wide body car. I think your wheels might even fit a stock body car with rolled fenders, stretched tires, and some camber. It's hard to say what size tire to run since I've never tried working with a 11.5. I would need to see the car and do measurements for myself before deciding. If I had to guess I would say start around a 255 or 265 width in the front and as wide as you want in the rear.
Old 03-24-16, 01:58 PM
  #5681
Stavros
Stavros's Avatar
Quick question guys.
SC400
Front: 18x9 ET20 with 225/40/18
Rear: 18x10 ET38 with 255/35/18
Will they fit without having to roll the arches?
I'm on slight drop on coilovers.
Thanks
Old 03-24-16, 02:31 PM
  #5682
Sactolex
Sactolex's Avatar
What size spacer to make 17x7 50mm offset flush but safe?
225/50/17
Old 03-25-16, 07:12 AM
  #5683
Deegee
Deegee's Avatar
Originally Posted by Sactolex
92 400
225/50/17
If I could even locate a spacer that would make this work, I still wouldn't run it. You may be able to fit the front flush, but not the rears. I'd find wider wheels with lower offsets to be safe.
Old 03-26-16, 03:22 AM
  #5684
Stavros
Stavros's Avatar
SC400
Thanks
Anyone? Looking at buying these wheels today if they fit.
Old 03-26-16, 11:11 PM
  #5685
jwynn
jwynn's Avatar
Will a 275/40 +40 19x9.5 fit fine all the way around with no problem? Should be from what I've research just double checking. thanks
Quick Reply: ****Official Wheel & Tire Fitment Guide for SC300/SC400****
