a/c on sc300 isnt working, why?
Guest
Posts: n/a
Hey, as you all know, So. Cal. is hot. My a/c gave up on me. THe a/c still works, but when its on full power, it works as though it was on low. Even with the fan turned on high, it's still low. whats wrong with my car? when the mechanic checked it out, he said the a/c was fine and that it was blowing cold air. Of course its blowing cold air, but its not as strong as before. thanks for your help
kevin
kevin
A/C not working properly
Most likely you are low on refrigerant gas. You can run A/C system diagnostics to find out error codes (if any) by checking http://www.users.bigpond.net.au/star...wers3.html#Q59
Your 92 use R-12 freon, you can't buy R-12 unless you have a certification. Get it recharged at a shop. Unless you want to change it to R-134a, I would get it recharge with R-12 for now. You be looking at around $100
Good Luck
Good Luck
Originally posted by Sc3005spd
do the recharge kits they sell work? thanks bye
