SC- 1st Gen (1992-2000)
Candy Apple Red taillights
Old 01-06-05, 02:08 PM
DlaxMan3
DlaxMan3's Avatar
Default Candy Apple Red taillights
I now a common mod to do on a 92 is to piant they orange part of the taillights red, but my question is do you have to remove the orange paint or can you just paint over it. And if you do have to remove the paint how do u go about doing so.
Old 01-06-05, 03:21 PM
/Aerostar\
/Aerostar\'s Avatar
Sand it down a little with some 400 grit if you want, then just paint right over it. Make sure to use a good high quality clearcoat and not Testors crap clearcoat
Old 01-06-05, 03:25 PM
AllBoutDaZ
AllBoutDaZ's Avatar
any pics of some all red??
Old 01-06-05, 03:36 PM
/Aerostar\
/Aerostar\'s Avatar
Ask (or search...) and you shall receive
Old 01-06-05, 04:45 PM
DlaxMan3
DlaxMan3's Avatar
another dumb question but do you paint the outside or inside
Old 01-06-05, 04:53 PM
ACleanSC4
ACleanSC4's Avatar
outside
Old 01-06-05, 04:54 PM
Rising_Sun
Rising_Sun's Avatar
What type(Brand Suggestions) of paint do we use? Clearcoat?
Old 01-06-05, 06:02 PM
/Aerostar\
/Aerostar\'s Avatar
Use Testors Candy Apple Red (Walmart, in the model car section), and then I guess Duplicolor clearcoat (the high heat stuff would probably last the longest)
Old 01-06-05, 06:42 PM
Kilo
Kilo's Avatar
I tried the candy red lens spray paint but didnt like the way that it came out. So I ended up using RED lexus paint and applied very light coats with an air brush followed by 2 coats of clearcoat. It came out fantastic!
Old 01-06-05, 07:23 PM
/Aerostar\
/Aerostar\'s Avatar
The Testors transperant candy apple works awesome!! Just look at the pics, but that technique may work also.
Old 01-06-05, 08:45 PM
kaotiq
kaotiq's Avatar
hmmmm. I don't know if this is a good mod. Anything that requires a spray can is civic ricer style. If you really want it done properly, I highly recommend that you have it taken to a body shop to candy coat it. I promise that it will turn out fantastic
Old 01-07-05, 07:12 AM
CleanSC
CleanSC's Avatar
We'll have to disagree here. All my spray can projects come out OEM or better. Whether under the hood, inside the car or on my all-red 97' tails.
The trick is admitting when you f'd it up and it was better before you started. This is where most fail.
https://www.clublexus.com/forums/sho...d.php?t=135630
Old 01-07-05, 10:06 AM
kaotiq
kaotiq's Avatar
Hmm, then you guys must be expert painters or former graffitti artists because I have yet to see one good spray can project come out properly. However, my fellow clublexus members might prove me wrong. Touche!
avanchieri
09-06-16 07:21 PM
Canesguy
07-16-15 07:51 AM
dosracin
10-23-08 06:47 PM
LazyAlex
04-04-06 01:57 PM
Quick Reply: Candy Apple Red taillights
