SC- 1st Gen (1992-2000)
Dynoed the 93 5speed yesterday!
Old 02-23-04, 09:45 PM
TGRich
TGRich's Avatar
Default Dynoed the 93 5speed yesterday!
Well, I dynoed my baby yesterday at the JPI Importz Dallas meet. The only mod I have is the dual electric fans. I ended up getting right at 175 rwhp and it looks like 163 tq. I did a search and the only thing I came up with for numbers on a stock sc was 176. I was expecting more with the fans, but I could be low for any number of reasons.
does anyone have any other numbers from when they ran their stock sc300 so I can compare? Let me know the year, mileage, auto/manual, etc.....
Thanks,
Tim
ps- the temperature was between 65 and 70 degrees and there was a mix of 91 and 93 octane gas in the tank. The pulls were done in 4th gear for a 1:1 tranny ratio.
Old 02-23-04, 09:59 PM
TGRich
TGRich's Avatar
Default First time up
Okay, it's a little messed up. I guess they were having problems pulling a tach signal for some reason
Because of that I didn't get a torque curve, only hp.
Old 02-23-04, 10:01 PM
TGRich
TGRich's Avatar
Default 2nd time up
We tried again, this time we got a tach signal, which gave us a torque curve. It still seems a little choppy though and looks as though it cut out at certain points. At least I have an idea. No other sc's had trouble getting a torque curve for their sc's- any suggestion as to why this happened?
Tim
Old 02-24-04, 12:55 AM
Angel
Angel's Avatar
Here is my graph, bone stock 1993
Old 02-24-04, 03:44 PM
TGRich
TGRich's Avatar
Any comments on my chart?? Does it look normal to you guys? I was comparing it to Angels, and mine looked way more jumpy than his. But, taking a closer look, I think it's just the way the graph is laid out b/c I my curve is relative to his at the same rpm.
Tim
Old 02-25-04, 04:05 PM
O. L. T.
Keeper of the light
Forum Moderator
O. L. T.'s Avatar
I got you beat tim, My car is bone stock and i ran two Greedy stickers down my a pillars and pulled 320 rwhp . then added the nawws across the third brake light and pulled 375 on pump gas
Old 02-25-04, 09:38 PM
TGRich
TGRich's Avatar
Wow, sounds like I need to get some stickers!!
Come on people- give me some feedback or posts some sheets of your own here!
I remember seeing a sheet for one of the guys in Illinois (I think it was quikturbo) after doing a tuneup, but I couldn't find it- anyone know where it is?
Tim
Old 02-26-04, 10:54 AM
adidosc
adidosc's Avatar
greedy? never heard fo them.
must be expensive!
Old 02-26-04, 12:52 PM
DHRP
DHRP's Avatar
LOL! Too funny.
Old 02-26-04, 01:26 PM
DIrEctQL
Chicago Lexus Club Moderator
DIrEctQL's Avatar
Tim
I don't remember Chris (quickturbo) putting his car on a dyno before he did the engine swap. I might be wrong. I dynoed my car when it was stock but I don't think I ever posted the sheet. I don't remember what the numbers were.
Chris
Old 02-26-04, 08:20 PM
lexcoupe
lexcoupe's Avatar
My baseline run was 185rwhp. That is for a 1992 sc3 5 speed. I had an Injen intake and a axle back exhaust. It has 120k miles @ 93 octane
Kevin
Since today, that has changed. Now its (check sig)
Old 02-26-04, 08:32 PM
TGRich
TGRich's Avatar
Kevin
Grrr.....I'm not seeing why I'm only at 175 then. I figured 175 would be bone stock, then the electric fans would give me 8-12 hp.
Maybe there's something I else I need to address. The spark plugs and wires are only 30k old, cap and rotor was changed about 10k ago.
Old 02-26-04, 10:23 PM
Buttercup
Buttercup's Avatar
The engine is probably leaking some compression and carbon build up is taking it over.
Old 02-27-04, 04:38 AM
legendary
legendary's Avatar
please not e you have heavier wheels on your car (TT). Those wheels were made for a car pulling more hp. You do understand the rule of unsprung mass, no? Do another run with your factory rims....perhaps the 99 5 spokes. I guaranteee you will see a difference. The tach was prob not hooked up to their machine properly. I pulled a 191whp in my Legend last weekend, so I know it is possible that those wheels are prob the culprit. It is the Type II with 230 hp, the Sc300 is 225hp, rwd - factor in 20% for tranny loss. That puts you in the neighborhood of 180whp. Lose the weight, and try again. Loss should be somewhat less with a m/t
Old 02-27-04, 05:35 AM
lexcoupe
lexcoupe's Avatar
my run was with TT wheels also.
Kevin
Quick Reply: Dynoed the 93 5speed yesterday!
