Navigation Nanny Override
Found this product on the HS250 forum (my commuter car). It lets you program the Nav system while driving. It does cost $174.99!
http://www.prestigioussociety.com/?page_id=1188
Right next to it is White(?) with a Blue stripe, #17. That's the parking brake one.
You cut it and the end going to the Nav unit needs to be grounded. There's a ground wire on the same connector. You can just connect to it. I believe it is brown in color. If not, then it would be white with a black stripe. Those are typical ground wire colors in a Toyota.
Essentially, that's all Nav override systems do. They cost an arm and a leg because they are using plug-n-play connectors. Some may have timeout logic when they cut the speed sensor. When the speed sensor is disabled, navigation operation stops and the bread crumbs no longer track. All other functionality is unblocked.
*All information above is to be used for educational purposes only. I am not responsible for any damage you may cause to your vehicle.
I have not done this to my RX just yet (only for research purposes ), but that is the information I have come across. So far, I have only grounded the parking brake wire.
Here's the DIY:
https://www.clublexus.com/forums/rx-...50-rx450h.html
It's a pain to get to the 4 bolts on each side of the Nav unit. So easy to drop them inside of the interior and never recover. I removed mine and never put them back in. I actually put sticky masking tape around the wrench to hold the bolt in place while I pulled it out.
JohnnyCake
05-17-12 02:07 AM
APU6speed
07-15-02 09:43 AM
