Change key fob battery warning
Old 12-04-14, 02:02 AM
hovbuild
hovbuild's Avatar
Default Change key fob battery warning
How to reset this on my 2012
Old 12-04-14, 04:44 AM
User 41924
User 41924's Avatar
Have you replaced the battery? It should quit alerting when the battery in the fob has been replaced.
Old 12-04-14, 11:35 AM
raylor4
raylor4's Avatar
Default Fob battery change
Use the mechanical key to separate the fob halves. Swapping out the old with new battery is straightforward. Battery is common and available in supermarkets and drug stores. If your car is a recent CPO, you are entitled to free batts from the dealer. If you are still getting the low fob batt. warning after changing the batts, something is wrong. You should not have to reset this announcement.
Ray A.
Old 12-04-14, 11:44 AM
hovbuild
hovbuild's Avatar
First I had a warning when the battery was going on the dash in red....I had to hold the fob next to the button to get the car to start.....I changed the battery and all seemed fine but then a warning came up on the nav screen to see the dealer to change ou tthe battery but I already done this and the remote works like it should.....The warning had a spot to click on saying not to shoe it again...That worked.
Old 12-05-14, 10:40 AM
Droid13
Droid13's Avatar
It sounds like they had a simple "scheduled maintenance" type alert setup. If so, it would have showed up at the date or mileage selected regardless of whether your fob battery was pooched or not. You can setup all kinds of alerts like this in the Nav system.
Old 12-05-14, 11:13 AM
kitlz
No, I don't play soccer!
Forum Moderator
kitlz's Avatar
^And you can turn them off too.
Old 12-05-14, 04:31 PM
cynalan
cynalan's Avatar
Default Battery Fob Reminder
I had a similar issue. I replaced the battery in the key fob and then subsequently received intermittent warnings. I thought... that's odd. After a couple of weeks I figured out that it was my wife's fob that was triggering the message when she was in the car. DOH!!
Schulzmc (06-05-19)
Old 12-05-14, 06:46 PM
Cruiter
Cruiter's Avatar
Ha Ha, that's too funny
Old 12-05-14, 07:29 PM
Tom558
Tom558's Avatar
I just changed them both after a year, in part to see if the remote range would improve (we did not see a dramatic difference), and will probably continue the annual program just to avoid any problems.
Old 12-06-14, 06:05 PM
m1964
m1964's Avatar
2.5 year on original batteries - no problem, no decrease in remote range.
My Q5 remotes are 5y. o. and are on original batteries. It is not about money, but why waste the batteries?
Old 12-07-14, 03:09 AM
hovbuild
hovbuild's Avatar
Because if your out and about and can't start your car what do you do? For a 4 dollar battery every 15000 miles or one year is better than walking. I also keep one in the glove box. I do this in our RDX as well and have shown my wife how easy it is to change them out, just in case.
Old 12-07-14, 07:14 AM
justin1203
justin1203's Avatar
$1 each in a 5 pack on amazon.
Dealer wanted over $30 to do this!
Old 12-07-14, 10:21 AM
raylor4
raylor4's Avatar
There's a thread somewhere in this forum about fobs eating batteries. Dead in one week or so. I suspect a defective fob.
Ray A.
Old 12-08-14, 07:03 AM
Droid13
Droid13's Avatar
I agree it can save a lot of annoyance just to replace the battery at regular intervals, but just FYI, you don't have to walk just because the battery dies. The fob can be recognized even when the battery is dead by holding it against the power button for a few seconds. It's a bit of a PITA but a lot less so than walking...
Old 12-08-14, 08:08 AM
Cruiter
Cruiter's Avatar
Default Just a note re: multiple fobs
Something to consider if you place two or more fobs on the same counter or same pocket or same purse routinely. They are tiny radios and constantly transmitting and receiving. It won't hurt them but doing this repeatedly will decrease your batteries at a much higher rate as their constantly talking to one another by trying to communicate and failing.
I keep mine at least 10 feet or more apart as a general rule.
Quick Reply: Change key fob battery warning
