Somewhat disappointed in RX backup camera
Old 04-08-15, 05:57 AM
  #46
BertL
BertL's Avatar
Originally Posted by Ward6096
So I wonder why so much difference? Did someone say there was a contrast adjustment?
On our 2013's press Menu, select Display, and you can access two options that may help:
  1. A general contrast slider at the bottom of that panel that effects everything
  2. If you select "Camera" in the upper right of the Display panel, a camera-only panel will come up where you can also play with some settings unique to the cam
Detail on p39 of the manual.
Old 04-08-15, 06:02 AM
  #47
Leap
Leap's Avatar
Because they went with a different camera in the later RXes.
Old 04-08-15, 06:21 PM
  #48
TechNut
TechNut's Avatar
Thanks Bert.
Old 05-04-15, 08:03 PM
  #49
Redsands
Redsands's Avatar
Hi all, new here. Just got a new 15 for my wife two weeks ago.
One thing I've noticed is that there is an ambient light sensor in the camera. When positioned in the garage the image was greyer, but I watched the screen as I pulled out slowly and as I slowly entered a more lit area the screen changed from more grey(while still in color) to full color. Like a switch had been flipped. Maybe what some are witnessing is the low light display.
I'm not sure what the benefit to this is, but it's certainly there.
Old 05-05-15, 07:35 AM
  #50
lexus114
lexus114's Avatar
well, i am just glad to finally have a back up camera so......
Old 05-12-15, 01:17 PM
  #51
rchays
rchays's Avatar
Default RX 350 Back up camera
With camera off center, I find it impossible to backup straight between lines. When I think I am between lines and I get out of the car I am embarassingly crooked. The off center camera is driving me nuts. Do you adjust to it over time? Has anyone had their camera moved to the center?
Old 05-13-15, 07:18 AM
  #52
lexus114
lexus114's Avatar
use your mirrors in the downward setting for parking in the lines. works much better for that. i only use the back up camera to make sure there is no bonehead walking behind me while im backing up (we have too much of that going on around here). and that there is no other obstruction directly behind me.
Old 07-10-15, 06:59 AM
  #53
LexusUgh
LexusUgh's Avatar
Default 2015 rx 350
I am astonished at how poor the back up camera is. It seemingly is pointed at the ground right behind the bumper - is "almost" b&W. And, no guide lines. With a car so poorly designed for visibility (kinda hard to look out the back with those rear seat headrests!) I'd have assumed the back up camera would be far superior. Wish there were guidelines - beyond about 4 feet the camera is a joke. I'm disgusted. I keep hoping to see someone come up with a fix. Sorry to be so negative but this simple technology shouldn't be a problem for a vehicle that cost 1/20th of a million dollars.
Old 07-10-15, 09:42 AM
  #54
litzdog911
litzdog911's Avatar
I wonder if your camera is mis-aimed. Can you post a photo of what it's seeing? Mine certainly does not appear to be "pointed at the ground right behind the bumper". But, yes, the guidelines would be nice.
Old 07-10-15, 11:24 AM
  #55
JDR76
JDR76's Avatar
Received 1,625 Likes on 1,035 Posts
The camera is far from impressive, but it does what it needs to do, which is to show the driver if there are any obstacles behind the vehicle that can't be seen out the mirrors or back window. Definitely is useful for more than just 4 feet.
Grid lines would definitely be nice.
Old 07-10-15, 12:54 PM
  #56
LexusUgh
LexusUgh's Avatar
Sorry that I'm unable to supply a photo of the rearview camera scene. Maybe with practice - perhaps a lot of practice - I'll feel comfortable with this semi-blind backing. It's certainly not an asset that Lexus ought to be promoting. I guess it's better than nothing but not much - I suppose I'm disgusted because I've seen far better rearview cameras on far cheaper vehicles. I just assumed Lexus would be better than the below acceptable that it is. Sorry for the rant, guys.
Old 07-10-15, 10:20 PM
  #57
Oldfart
Oldfart's Avatar
I am driving Acura TL and my wife's RX is our family car. I see no difference between the two back up cameras.
Old 07-11-15, 10:40 AM
  #58
1111GS
Forum Moderator
1111GS's Avatar
But that would be comparing apple to orange. I think all other models have way better camera. We are spoiled and expect high(er) quality on our Lexus.
at first I found it really annoying and disappointing esp. they put better cameras in Venza and Sienna. But once I drive the Sienna for a while and got back to the RX, I have no more complaints. I don't mind the poor camera quality anymore.
Old 07-12-15, 09:42 PM
  #59
lili43
lili43's Avatar
Being off center drives me nuts. In fact, its probably the only negative gripe I have.
Old 07-18-15, 10:32 PM
  #60
Johnknee
Johnknee's Avatar
Yeah I experienced the same thing going under a bridge. My map turned into a greyscale and I thought I had done something wrong. But maybe it's based on the lighting around you?
Quick Reply: Somewhat disappointed in RX backup camera
