TRANSMISSION COOLER for TRAILERING
Old 12-03-13, 09:09 PM
TonyA177
TonyA177's Avatar
Default TRANSMISSION COOLER for TRAILERING
Hi Guy's.
I own a 2012 RX 350 unfortunately without a tow prep package. I am interested in being able to pull a utility type trailer with a gross weight of about 2,000 lbs. I would be used once or twice a month for about a 200 mi. trip, and once a year for about a 2,000 mi trip. I know it is easy enough to install a trailer hitch and necessary wiring. I am however, concerned that I don't have a transmission cooler. Will I do any damage to the transmission without one? Are they prohibitively expensive to have one installed? Is are there any good after market coolers I should consider?
Your thought would be greatly appreciated.
Tony A177
Old 12-04-13, 02:51 AM
mshumack
mshumack's Avatar
Originally Posted by TonyA177
Hi Guy's.
Tony A177
Why not install a transmission temperature gauge first. Pull your trailer around and see if the transmission temp gets too hot. I would want a gage regardless, and if the temp stays low, you won't need to spend the $ on a cooler.
There are a lot of selections and they are pretty easy to install. Check out Summit Racing http://www.summitracing.com/search?S...rature%20gauge
Also, here is a link to transmission coolers (generic add-on style) http://www.summitracing.com/search/m...ssion%20cooler
Old 12-04-13, 05:36 AM
jrfiero
jrfiero's Avatar
If I'm not mistaken the RX is rated for towing a 2000lb trailer WITHOUT a towing package. The towing package bumps it up to 3500.
If you're not in Death Valley you should be fine.
Jonas
Old 12-04-13, 06:14 AM
oohpapi44
oohpapi44's Avatar
If you're going to be making tow hauls once or twice a month, go and have one installed. They are not expensive and any potential damage is going to be way more expensive in repairs.
Not worth taking the risk of nearing the max tow weight without a tow package to save a couple hundred bucks.
DetailsGrl
RX - 3rd Gen (2010-2015)
70
09-08-21 08:45 AM
Brussell
05-25-19 08:05 PM
badgers11
03-10-14 01:55 PM
Rontan
09-28-12 12:18 AM
Quick Reply: TRANSMISSION COOLER for TRAILERING
