2006 RX330 OCV(VVT) Solenoid and Strainer preventive maintenance
Old 06-19-15, 08:52 PM
5W40
5W40's Avatar
Default 2006 RX330 OCV(VVT) Solenoid and Strainer preventive maintenance
What does a VCT or VVT Solenoid Do?
VCT or Variable Cam Timing solenoid is a device used in modern engines to change camshaft position timing in relevance to engine speed and engine timing allowing the engine to produce more horsepower without adding excessive overlap to the camshaft design.
The way the VCT Solenoid works is as follows:
The VCT solenoid works with oil pressure, it receives a signal from the ECM when the camshaft needs to be rotated either in the advanced mode or retarded mode depending on engine load and speed. The VCT solenoid is able to accomplish that by altering the oil flow in the passages that lead to the cam phase(s), there are passages to advance the valve timing (open the valves earlier), and passages that direct the oil to retard the valve timing (open them later)
What is the Purpose of the VVT System?
The purpose of the VCT or Variable Cam Timing system is to allow the engine to move larger volumes of air in and out of the cylinders to generate maximum horsepower.
Vehicles with DOHC (Dual Overhead Cam) engines usually have two VCT solenoids mounted in each cylinder head, one for each camshaft, allowing the Engine Control Computer to activate each VCT timing mechanism in each Camshaft separately.
NOTE: The Cam phase is mounted on the front of the camshaft(s) it is driven by the engine’s timing chain or timing belt depending on the engine’s design.
Oil Control Valve=OCV or VVT Solenoid
2006 RX330 AWD 195K km w/ routine maintnance, Never see CEL!
This is a quite straight forward job, so just pick some pictures for job clarity.
Both Bank1 and Bank2 OCV are underneath these tubes
A closer look
Bank 2 OCV
Bank 1 OCV
Need remove air filter box
Red one is Solenoid bracket bolt, yellow one is the strainer bolt
The solenoid looks pretty good shape, not debris at all!
Clean both with gasoline
Bank 1 OCV and strainer bolt, I didn't remove them as the first one looks pretty good shape.
The following 2 users liked this post by 5W40:
aminsa (07-05-17), Margate330 (03-09-21)
Old 07-07-17, 07:38 AM
Arthurirw
Arthurirw's Avatar
Any reccomendations on what to use to clean, and great info, thank you.
Old 07-07-17, 08:29 AM
5W40
5W40's Avatar
I wash them in gasoline.
Old 07-07-17, 04:30 PM
mdbrown
mdbrown's Avatar
For me it's brake cleaner.
Old 03-09-21, 03:04 PM
rx330March
rx330March's Avatar
great pictures, but can you clarify, bank 1 is the one in back and bank 2 in front? I got a little confused with the pictures.
Old 03-09-21, 07:55 PM
5W40
5W40's Avatar
You are right, Bank 2 in front.
Old 03-09-21, 09:21 PM
Margate330
Margate330's Avatar
+1 Awesome job from OP.
1st Class walkthru with pics, very much enjoyed.
Old 05-08-21, 08:59 PM
PlatinumV8
PlatinumV8's Avatar
Nicely done, have the replacement OCVs for my RX and now I know how to do the job from your pics! Thanks!
murphysf
RX - 1st Gen (1999-2003)
02-04-18 12:45 AM
Carheart
01-05-18 09:10 PM
aymaddemir
08-24-15 02:50 PM
buckeycat
07-10-15 10:25 PM
MattLS400
04-01-14 07:15 PM
Quick Reply: 2006 RX330 OCV(VVT) Solenoid and Strainer preventive maintenance
