RX330 Suspension Mystery
Old 12-06-14, 01:07 AM
Jdawgg
Jdawgg's Avatar
Default RX330 Suspension Mystery
06 330 4WD Replaced control arms, tied rod ends, ball joints and had aligned. Now it somehow appears that the suspension is stuck in the high position, there is no movement in the front struts. It sounds like there is no motion from any suspension components. Feeling a bit stupid here...everything looks correct. Any ideas would be greatly helpful. So Disconnected battery and suspension is actually active now. But each corner is at a different height, will not return to Normal or low position
Old 12-06-14, 01:54 PM
HtownBlue
HtownBlue's Avatar
When you post next time friend, be more specific. You failed to mention if you have air suspension or standard.
My guess is you either have an issue with your height sensors which are attached to control arms, or you have a leak in one of the struts. You could also have a problem with the valves that send the pressure to each strut though the first two are more common. I would also check to make sure the pump is functioning.
Make sure they reattached the height sensors to each control arm too.
gymraeg
02-05-18 11:10 AM
xfactor70
16
06-18-10 09:24 PM
aparker813
06-02-09 11:01 AM
Lexus082
Suspension and Brakes
11-23-07 12:32 AM
SeattleGS400
12-17-03 01:03 PM
Quick Reply: RX330 Suspension Mystery
