o2 sensor bank 1 sensor 2
Old 06-19-14, 09:33 AM
jbuchanan
jbuchanan's Avatar
Default o2 sensor bank 1 sensor 2
I have and 05 rx330 the car was throwing p0037 so I replaced the sensor and check engine light still on vsc/ trac still on also will it go off on its own or do I need to reset computer thanks
Old 06-19-14, 06:40 PM
kiwi
kiwi's Avatar
you will need to reset the light. if you dont have a scan tool, you can remove the negative cable from the battery for a few minutes. you will have to reset your windows and radio etc. though
Old 06-21-14, 10:19 AM
yennit
yennit's Avatar
I went toy local auto store, borrowed the code reader and reset the codes.
Old 06-21-14, 10:37 AM
HarrierRX300
HarrierRX300's Avatar
I had the same situation. I disconnected my battery and the check engine light disappeared. My question is, the error came on for a reason so resetting should only help temporary?
Old 06-23-14, 06:09 AM
jbuchanan
jbuchanan's Avatar
U need to have the code read by auto zone cause the light will come back on
Srinivasak
RX - 1st Gen (1999-2003)
19
10-20-19 03:54 PM
Crossxup11
06-19-19 07:04 AM
Andyboy980
02-13-16 09:19 AM
Kumar350
11-16-14 09:03 AM
Saurabh
11-11-09 05:37 PM
Quick Reply: o2 sensor bank 1 sensor 2
