Diagnostic Menu - fault codes
Old 02-25-14, 10:59 AM
spacecraft
spacecraft's Avatar
Default Diagnostic Menu - fault codes
Today I tried to access the hidden menu by pressing the info button and switching on and off the park lights four times, as explained in previous threads.
Btw, I found it mentioned for another RX version and model year, but it did work also on my 2008 400h, just in case anyone would want to try it.
In fact, I'm not posting this in the hybrid section because I don't think it's something H-specific.
Anyway, I actually didn't find anything in it worth writing home about.
The only thing which made me curious are a couple of pages showing some error codes.
The first pic below is the one accessible through the "Service Check" option of the main menu, and the other two came up pressing the respective "CHECK" orange buttons.
Now, is there anyone who has the faintest idea of what the fault codes mean?
Fwiw, the car is loaded with everything aside from the rear DVD, and all gadgets seems to be running just fine...
Old 02-26-14, 08:20 AM
neelnaik
neelnaik's Avatar
https://www.google.com/url?sa=t&rct=...61965928,d.b2I
That link is a download link for diagnostic codes for a prius, but I think it would be the same for the RX.
If everything is working fine, then I wouldn't worry about it too much. It almost seems to be more of a log then anything.
Old 02-26-14, 10:53 AM
lexus114
lexus114's Avatar
[QUOTE=spacecraft;8400297]Today I tried to access the hidden menu by pressing the info button and switching on and off the park lights four times, as explained in previous threads.
What the Hell is that?? Hahahahaha!
Old 02-26-14, 12:01 PM
neelnaik
neelnaik's Avatar
That's the procedure to get to the "hidden" diagnostics screen on vehicles with nav. It's always some sort of crazy procedure, so a consumer wouldn't be able to get to by accident.
Old 03-03-14, 07:16 AM
spacecraft
spacecraft's Avatar
Interesting stuff, many thanks.
Actually, even if the codes look quite similar, the descriptions (and their numbering) are a bit cryptic.
I can see how "my" codes match one "category" of codes, but I struggle to associate to them one more specific description.
For instance, the very first code in the page you linked is O1-D5, which is also the first in my second pic above.
As I understand, the category is "absence of registration unit", but I can't see how to match my "Sub Codes" with those in that doc....
Oh well, I guess you're right in suggesting to not bother a lot about all that!
Old 03-03-14, 12:23 PM
kickin8
2IS/2RX/4RX
kickin8's Avatar
not 100% sure but I think you can get the codes from techstream?
https://techinfo.toyota.com/techInfo...rog&_nfpb=true
Old 03-03-14, 04:46 PM
spacecraft
spacecraft's Avatar
Well, I hope so.
I'd surely be pixxed, if after forking out $5k+ for that thing, it would actually be useless.....
Old 03-13-14, 01:22 PM
Eliaquim
Eliaquim's Avatar
Hello!
Is there a way to access fault codes if I do not have navigation?
Old 03-13-14, 02:39 PM
RX330inFL
RX330inFL's Avatar
You might find something here of help:
https://www.clublexus.com/forums/rx-...ii-reader.html
They make more expensive OBDII scanners, but if you have an Android device or a Bluetooth capable computer there are enough free and/or cheap software packages for most individual's needs.
Old 03-13-14, 05:12 PM
spacecraft
spacecraft's Avatar
I also have a bluetooth OBDII interface, and an Android phone with the Torque app.
It does work with my 400h, but it never showed any fault code, while the hidden nav screen menu brought up those in the above pics.
I suppose it's because those generic apps are only good for the more basic parameters.
In fact, the app in theory should read the oil temperature (both engine and transmission), but it doesn't work. Coolant temp works fine, instead.
lexluthor5
01-23-23 12:52 PM
Magellan55
Maintenance
06-26-21 02:40 AM
naivelin
04-10-19 10:48 AM
lexus114
RX - 3rd Gen (2010-2015)
06-29-16 07:35 AM
over40driv
Performance & Maintenance
08-10-08 07:17 PM
Quick Reply: Diagnostic Menu - fault codes
