burning oil smell...
Old 12-12-13, 02:16 AM
RuninRoach
RuninRoach's Avatar
Default burning oil smell...
Burning oil smell but can't figure out where or why.
No Drips (checked standing on dry ground).
No Drips (checked after spraying water down on ground).
Checked Oil, level doesn't change.
Checked Transmission, level doesn't change.
Only thing that has changed is that i went with a 5w-40 oil about 4000km ago. Could it be burning minute amounts of oil during driving under hard conditions (mountains/hills)?
Old 12-12-13, 03:15 AM
RX330inFL
RX330inFL's Avatar
Check your PCV valve.
Old 12-12-13, 03:28 AM
RX330inFL
RX330inFL's Avatar
BTW, I cannot fathom why you would want to run a 5W40 motor oil in your RX. I understand the 1MZ-FE you have in your version is tough on oil, but I would think that using a 5W30 or 5W20 synthetic would be a better choice. Heck, I run a 40 weight oil in my Chevelle and that is over forty years old.
Old 12-12-13, 07:39 AM
jfelbab
jfelbab's Avatar
Maybe check your gaskets for a small drip over the exhaust manifold.
Old 12-12-13, 11:54 PM
Saltynutz
Saltynutz's Avatar
Check your cabin air filter?
Old 12-13-13, 09:24 AM
lexus114
lexus114's Avatar
+1 for the PCV Valve, and +1 for using 5W-30 motor oil.
Old 12-13-13, 10:29 AM
RX330inFL
RX330inFL's Avatar
Keep in mind that RuninRoach is over in Hong Kong and has the previous generation's 3.0L engine in his otherwise 2nd Generation RX. It is definitely a bit harder on oil. Though, I think the 5W40 is too thick for this application. A synthetic would be the way I would go instead of a heavier weight oil.
Old 12-13-13, 06:15 PM
jfelbab
jfelbab's Avatar
Wasn't that the sludge prone engine?
Old 12-13-13, 06:54 PM
RX330inFL
RX330inFL's Avatar
Yes. They did not get the 3.3L engine until the following year. Have concerns as to what the heavy weight oil plus the strain being put on the engine on those hard trips he was talking about. Wondering about foaming, etc.
Old 10-09-14, 02:32 AM
RuninRoach
RuninRoach's Avatar
Turned out to be a Engine Cylinder Head Cover gasket that needs to be replaced....anyone know what that involves? dealer charging me $400 including parts and labor.
Old 10-09-14, 03:31 AM
Carver
Carver's Avatar
Front one or rear? If it's the rear one might be a good time to think about plugs if the mileage is close.
Old 10-13-14, 08:47 PM
RuninRoach
RuninRoach's Avatar
mileage is under 100k miles......don't know if front or rear but from the location of the leak looks like rear.
Old 10-14-14, 02:35 PM
alchemist
alchemist's Avatar
nail on the head. Do your plugs at the same time as well as intake manifold and valve cover gaskets.
gerald423
04-14-18 07:20 AM
fwig1988
RX - 1st Gen (1999-2003)
19
01-17-14 08:10 AM
ThumperPup
ES - 5th Gen (2007-2012)
12-13-13 02:51 PM
amerquresh
05-11-12 06:39 PM
rsr2216
17
03-20-12 08:38 PM
Quick Reply: burning oil smell...
