RX330 - one window fail to reset/reprogram
Hi all,
I got a problem with only ONE of my power windows after I reinstall a new battery.
I'm aware that windows and sunroof/moonroof need to be reprogrammed if the battery is unplugged.
I managed to program all the windows except one ....the one on the right passenger side.
No matter how I tried, I couldn't get the blinking light turn solid....and I can't get the automation or control from driver.
Plug and replug battery, reprogram with half push, full push, 1 second, 12 seconds, 15 seconds...no luck...
Any answer for that?
many thanks in advance.
Hi, thanks for your reply.
I brought the car to auto electrician.
He said that the motor couldn't send signal to the computer/board...so need to replace the motor.
I'm thinking to replace it myself.
Wondering how hard is it to do it myself?
Similar problem here.
replaced the battery also. The passenger window will not operate from the drivers side switch. All others work fine. The passenger switch works fine but the drivers side switch does not. I disconnected the battery again for a few minutes with the same result.
Any ideas?
ETA: Search is your friend. Thanks all anyway.
Any ideas?
only on one window like me?
or all window?
Have you re initialize?
My case is the window is not initializing regardless how many time I tried and only on 1 stubborn window
or all window?
One window.
Easy to search for, a common issue.
For my problem I had to: With key on, lower window and continue hold the button down for 6 seconds. Raise the window completely and continue holding the button down for 6 seconds. Fixed it!
The thread I searched also referred to "Page 74 of the owners manual" which I haven't looked at but may have more info on the subject.
Hold down passenger side switch until window rolls all the way down AND CONTINUE TO HOLS IT DOWN FOR AN ADDITIONAL 3-5 SECONDS. Then troll all the way up holding button up and hold up for an additional 3-5 seconds. Then driver side switch should work.
Thanks for the reply guys.
As I mentioned earlier, I was aware with the reinitializing/reprogramming windows and I have done it few times.
It worked for all 3 windows except one on the rear right side.
went to see 2 mechanic, one told me it's the switch at the driver side, one told me it's the motor faulty (can't send signal properly to the switch).
akhosravi
07-26-19 07:10 AM
toy4life
02-27-12 10:06 AM
