2005 RX330 Whining From Engine Compartment
Old 11-21-13, 10:01 PM
01LEXPL
01LEXPL's Avatar
^ yep, that's what I heard for a few months before mine blew on my ES300...
Old 12-04-13, 11:00 AM
chazman6
chazman6's Avatar
Default Got a RX350 Hummer
Moved this earlier post to here even though I'm in a different generation
I'm a "newbie" at this Forum and my RX ('13) just turned 3 K. Not sure I'm at the correct Thread,
but the sound coming from under the hood is a major disappointment with my new luxury vehicle.
At start-up, we get a humming/whining sound which gets higher in pitch with acceleration.
The Tach. actually resembles a frequency meter.
This continues for approximately 8 - 10 miles and eventually disapates. Can't blame it on the weather since it did it @ 80 degrees back in August and @ 24 the other morning.
Had it back to the dealer once but the Tech supposedly could not hear it.
Has anyone else encountered this problem or have I purchased a soloist ?
Old 12-04-13, 11:05 AM
jbl-1985
jbl-1985's Avatar
Chazman6:
I don't honestly know if my car always made this sound or if it just started. I am sitting tight for now. The clear advantage I see that you have is that your car is still under warranty and I would not hesitate to take it back to your dealership and ask them to look into it. If you do, please report your results here.
Thanks,
JBL
Old 12-05-13, 09:19 AM
mowmow
mowmow's Avatar
chazman6, you said it yourself your problem start when it's at startup, I assume it's cold startup, so no way a service tech can hear the problem if you've already drove it for a while engine is all warm up and all. I would ask service department to let you leave it overnight give you a loaner then have the tech with you start the car in the morning and reproduce the sound/problem.
Old 12-05-13, 10:21 AM
Rainbird
Rainbird's Avatar
Originally Posted by chazman6
Not sure I'm at the correct Thread, but the sound coming from under the hood is a major disappointment with my new luxury vehicle.
The correct forum for your vehicle is the "third generation". You might do a search there to see if any other 3rd generation RX350 are having this problem. Here is the link:
https://www.clublexus.com/forums/rx-...eneration-212/
Old 12-05-13, 06:38 PM
chazman6
chazman6's Avatar
Thanks to my 2 responders for your input and pointing me to the proper thread'.
FYI, my visit to the Dealer was an overnighter since they were told the problem begins @ start-up.
My big concern is that someone started the RX, went to another job, and returned 30 minutes later
after the vehicle was hot.--- and heard nothing.
Old 12-05-13, 09:26 PM
HtownBlue
HtownBlue's Avatar
That is a prototypical belt issue. Have them look at the belt tension. Then see if the A/C has enough refrigerant oil in it. I bet the noise changes when you turn off AC.
Old 12-06-13, 05:52 PM
chazman6
chazman6's Avatar
Default Hummer
Don't beleive the AC is an issue.
The AC is is rarely ON at start-up but if it were needed, most likely would still be running during an 8 - 10 mile ride.
I will definately look into the belt tension since it should be less after the warm-up stretch.
Old 03-27-18, 05:23 PM
RX711
RX711's Avatar
Did you figure out the noise?
Old 03-27-18, 07:23 PM
jbl-1985
jbl-1985's Avatar
Took it to a respected tranny shop last year, the guy test rode it and wanted to do about $500 in diagnostics. It is the transmission and nothing else. I just looked at the first thread, and it was in November 2013, and by the time I wrote that original post I had noticed it for almost a year...It's now March 2018 and the noise is still there. I am nearly convinced that the car is going to sing like this for the rest of it's natural life, or die. I decided not to chase the problem down - if the tranny takes a dump I'll have it replaced or rebuilt. It's bee a really long time since it started - I almost think if something was going to happen, it would have happened by now.
Old 10-07-20, 09:43 AM
jbl-1985
jbl-1985's Avatar
Noise still there. Car runs great otherwise. Ignoring the noise.
bonds1971
08-05-17 10:05 AM
sbjust
04-22-16 01:34 PM
Ontario
04-27-08 10:39 AM
GFC350
11-29-07 10:35 AM
Quick Reply: 2005 RX330 Whining From Engine Compartment
