engine shield cover advice
Hi, so there is a noise that comes on the car at highway speed....we put it up on the ramp, and noticed the engine shield to be loose, as some screws had fallen off for some reason
Anyways, want to get a replacement shield, any thoughts (i dont think those screws are available aftermarket)
was looking at this site
http://www.jcwhitney.com/2007-2009-l...07-2009j1.jcwx
thanks
thanks
i had a simliar problem. just bought some self tapping screws and re--secured it. i have had it off and on several times since to do oil changes, and its holding up great
Is the original still intact and usable or is it now damaged? If it is good then you just need a set of new pins/clips, depending on what is missing, which are relatively cheap. Should only be $1 or $2 a piece at the dealership.
http://lexus.sewellparts.com/oem-cat...X330-2004.html
As for the part you listed, not even sure that comes with new pins/clips for your use.
sammy5001
10-10-23 10:19 AM
docdgt@com
08-14-07 02:04 PM
