Rx330 power lift gate woes
Old 07-27-13, 08:18 AM
Henry06
Henry06's Avatar
Default Rx330 power lift gate woes
just recently bought a low miles 77k 2004 rx. Well today my wife picked me up from the train station I hit the button to close the rear latch I got nothing no noise beep, nothing. What could it Be. I called the dealership since it's with in 30days. They already replaced the power rack steering.
Old 07-27-13, 09:32 AM
Carver
Carver's Avatar
It maybe as simple as a failing fob battery, that's the cheapest place to start!
Old 07-27-13, 10:40 AM
Henry06
Henry06's Avatar
I was hitting the button on the lift gate. I searched the forums didn't see much other than confirming the button in the glove box was pushed in
Old 07-27-13, 12:18 PM
Carver
Carver's Avatar
Did you try the fob and the dash switch? Have you disconnected the battery lately?
Old 07-27-13, 01:31 PM
Henry06
Henry06's Avatar
Not that know of, we dropped it off earlier this week so they could fix the power steering rack which it Failed safety inspection due to it. They also fixed the glovebox latch, may be something got disturb? Now I have this issue.
I tried the fob and the button on the dash.
Old 07-27-13, 02:12 PM
Carver
Carver's Avatar
A battery disconnect can cause various systems to need resetting. Are your windows , sunroof and locks operating normally?
Old 07-27-13, 03:16 PM
Henry06
Henry06's Avatar
Let me go check and confirm, Im pretty sure they all work.
And I didnt know that disconnecting the battery can cause power options to be reset. This is good to know
Old 07-27-13, 03:48 PM
Henry06
Henry06's Avatar
All power functions are working except the liftgate. The darn thing doesnt even beep like it use too. Just silence.
Old 07-27-13, 04:02 PM
JLeffler
JLeffler's Avatar
Oh yeah...doesn't make sense does it? We changed a fuse and had to fix the windows and sunroof. You would think that a sunroof is a sunroof, but apparently not after you change a fuse or battery....same with windows. Very odd behavior.
Hope you figure out your liftgate. That is frustrating. Our liftgate does not open by hand and we require the remote control... for some reason it doesn't open on it's own and needs to be forced....
Old 07-27-13, 04:17 PM
Henry06
Henry06's Avatar
Is there anything I can check other then mentioned so far, Im pretty mech incline we have an is300 which I maintain and my 1995 impala ss. I dont mind getting my hands dirty just need to direction since this car is new to me.
Old 07-27-13, 05:01 PM
Rainbird
Rainbird's Avatar
[QUOTE=Henry06;8060436I called the dealership since it's with in 30days. They already replaced the power rack steering.[/QUOTE]
That steering rack repair is expensive. It sounds like you have a 30 day agreement with the dealership to fix anything that is wrong? Maybe you should get them on it before it's to late. We would just be making a guess. My thinking is a bad motor.
Old 07-31-13, 12:11 PM
Henry06
Henry06's Avatar
Well the replaced the steering rack and glove box. Almost 2k in parts in labor, but no door.
Im on the hook for this, not that upset. I just need to figure out what the heck happened. It worked then it just stopped. Has this symptom happened to anyone else?
Old 07-31-13, 12:32 PM
Carver
Carver's Avatar
It's rare but it does happen. Search 'tail gate', 'rear deck' and your favorite, 'lift gate' for some ideas on what happened.
Old 07-31-13, 12:39 PM
RX330inFL
RX330inFL's Avatar
Did you perform a continuity check on fuse #4 inside the engine bay to make sure it is good?
http://drivers.lexus.com/t3Portal/do...004rx33/64.pdf
Old 07-31-13, 01:52 PM
Henry06
Henry06's Avatar
I did not check the fuses, I will check this eveing with my test light. I can hear the power door latch grapper thingy once you close the rear latch. I just get no sign of life from the power lift gate when you activate it.
Quick Reply: Rx330 power lift gate woes
