rx 330 2004 confused with what ipod adapter to buy
hello i want to buy a ipod adapter to my rx 330 04 is mark levinson stereo with no dvd player at the back and it dosent has sat in the am **** and i dont know what to get isimple ,grom usaspec
or vais and the other thing is with one of this adapter can i see the ipod playlist in my nav system or is only with the satelite radio option
I have a VaisTech which currently has a XM receiver plugged into it and a Belkin AirCast. I recently removed my Harmon Kardon Drive and Play, which was plugged into the Vaistech. (the Drive and Play is a very good ipod interface. but Belkin AirCast works better for iPhone).
I could be wrong, but I don't think there is any way to put iPhone or iPod playlists on the NAV system, period.
I know for some Toyota and Lexus head units, there are iPod interfaces that do CD changer emulation, which is what Vaistech does. So that might give song title, but only on the little LCD screen that you cannot read.
While it's a separate display, the Harmon Kardon unit worked well, but you still need a separate box like a Vaistech along with it.... the Drive and Play only has Aux out, and the factory radio has no aux in, unless you have a module for that.
Personally, I use a Belkin Aircast...this gives handsfree blutooth for the iPhone thru the radio (that sounds better than the factory handsfree option) AND it does music thru Bluetooth Audio gateway
USA Spec iPod adapters works!
I have a 2004RX with ML sound, no SAT... and installed a USA Spec iPod adapter part number 581PA15TOY from Crutchfield. I've used it with several iPods, and iPhone 5 (using an adapter since it has the older iPod interface). It disables the CD multichanger. It allows you to specify five playlists with a specific name, which the steering controls will then cycle through either those five playlists or through songs in a playlist.
