Airbag Light
Old 05-16-13, 12:18 PM
ManXP
ManXP's Avatar
Default Airbag Light
Searched the forum, not much info found.
I have a problem with Airbag light - it blinks in the dashboard. The dealer turned it off twice (by connecting their computer) but it came back again. I'm pretty sure (and the dealer thinks the same) the problem is related to wiring because the light does not blink sometimes. And, when it does not blink, sometimes it starts blinking again, especially when I drive fast and make a "sharp turn" (hope that makes sense).
So far, I only know the faulty airbag is in the driver's seat (the dealer told me so). Since they turn the light off and it comes back again later, they suggest me leaving the car in the service, so they can remove the driver's seat and check the issue.
Someone had a similar problem and can tell me aprox cost?
Old 05-16-13, 01:18 PM
Rainbird
Rainbird's Avatar
The Lexus Restraint System Warranty is for 72 months or 70,000 miles. Is your vehicle within the warranty period?
Old 05-16-13, 01:34 PM
ManXP
ManXP's Avatar
Mine is 74 months
Old 05-16-13, 06:52 PM
Dadikins
Dadikins's Avatar
When did you first bring this to the dealer's attention? If two months ago, you should hopefully be covered.
Posted from ClubLexus.com App for Android
Old 05-17-13, 01:42 AM
ManXP
ManXP's Avatar
Any page with the exact info (so I will know what to tell to the dealer)? Google didn't help much.
P.S. I'm outside US, not sure if we have the same type of warranty here
Old 05-17-13, 03:15 AM
RX330inFL
RX330inFL's Avatar
Perhaps the Seat Slide Position Sensor or the Occupant Detection Computer...
http://lexus.sewellparts.com/oem-cat...X350-2007.html
However, like many of these types of gremlins it is hard to pin down without the right test equipment and even then it is a long drawn out process of elimination. Dealers will normally not give a price on the repair as they do not know how long it will take to find the problem let alone what part(s) will need replacing if any at all. Could simply be just a loose connection. Then, they could think they have addressed the problem only for the light to come back on for you 5 miles after leaving the shop. If it were a warranty repair they might replace multiple parts at one go to include the airbag itself and hope that solves the problem, however, if you are paying for the repair that would be very expensive.
If the Airbag light is coming on then that means there is a signal being sent to turn it on. What is that error code and what is responsible for sending it?
Old 05-17-13, 03:21 AM
ManXP
ManXP's Avatar
Not sure of error code. Anyhow, the car is going for a scheduled maintenance to the dealer next week, will ask them to look at the problem again.
Old 05-17-13, 08:01 AM
DPJ
DPJ's Avatar
I can tell you it's a common problem on Subaru's. It's usually just the yellow connector is loose under one of the front seats.
Old 05-17-13, 03:07 PM
RX3302004
RX3302004's Avatar
I may be way off on this, but our brake light switch was causing all kinds of idiot lights to go off on our 04 model.
Old 05-17-13, 05:21 PM
Rainbird
Rainbird's Avatar
Lexus has a TSB on the SRS Warning Light. Perhaps this will help when talking with the dealership.
File Type: pdf
Old 05-18-13, 06:37 AM
ManXP
ManXP's Avatar
Thanks a bunch
Old 08-24-14, 06:50 AM
altecsound
altecsound's Avatar
dealer said it is an open, service bulletin, no air bags will work, $1800 to fix
called Lexus, will hear back next week
Aug 23, 2014
GadgetRick
GX - 1st Gen (2004-2009)
13
08-26-17 09:51 PM
aznlonly
09-23-12 04:51 AM
aznKewlguy
09-07-11 06:08 PM
WillRobin
RX - 1st Gen (1999-2003)
10-21-10 01:44 PM
rg_gibson
08-16-09 08:38 AM
Quick Reply: Airbag Light
