Last edit by: IB Advertising
Browse all: Lexus IS Engine and Powertrain Guides
- Lexus IS GS: How to Replace Your Serpentine Belt
Step by step instructions for do-it-yourself repairs
How to change the serpentine belts on a RX330?
I assume you are referring to the accessory belts and not the timing belt. Some info here:
https://www.clublexus.com/forums/rx-...diy-belts.html
Yes. Loosen the adjustment bolt that is near the alternator and loosen the adjustment bolt at the power steering pump. Ths will loosen both belts and you can change them. No need to even touch the radiator.
