Mystery coolant leak 2004 RX330(58,000 miles)
Last 5 weeks noticed small coolant leaks on driveway and also find coolant droplets on underside of front plastic cover under engine between front wheels.Dealer did a quick check under car and could find no evidence of leak. Coolant (original equipment red liquid) level seems o.k. and I am keeping an eye on it. I am sure it is not transmission oil because the drops are watery although the consistency of each fluid is similar.
Any help would be appreciated with this issue. Guess I may have to pressure check the vehicle and maybe look at water pump/timing belt replacement but don't want to go to this expense until I am sure where the leak comes from..
The weak spot of the radiator is at the bottom similar to what is shown in the picture found on the following thread:
https://www.clublexus.com/forums/rx-...vel-issue.html
