16 inch wheels
As stevesxm had pointed out on a previous thread, you can put any size wheel and/or tire on your vehicle you want. There are plenty of calculators out there on the Internet to assist. The bigger question is why??? A 17" wheel is plenty of clearance for chains. Anything else is just silly, IMO.
A tire size around 205/75-16 might work.
The standard rims on the RX is 17" 6 spoke. Why 16"?
Ok i found a set of wheels rom an acura tl, same bolt pattern, same width, same offset, and everything BUT the bore or hub is 64.1 on the tl wheels, and 60.1 on the rx, i think, will these still be able to work? I know they won't fit if its a smaller bore wheel going onto a bigger hub,ex) lexus wheel on acura, but what about vice versa?
