Panic - Dropped nuts
While I tried to install the IPOD adapter to my 2009 RX 350, I dropped the top two nuts inside! and couldn't retrieve it by any means. One of them, i can spot where it is, but can't reach. The other one, i wonder where it went. I just put back the radio (CD changer), and tightened the bottom two nuts. It seems to fit, but i am worried about the two of them i dropped inside, also worried if on the long run this could cause a cosmetic issue in the dash.
Suggestions / advice please!! much appreciated....
Thanks
Thanks
The good thing is that the nuts are magnetic.
When I did my radio swap, I drop the nut twice. First one I was able to see where it went and the second time I had no clue where it went.
I had one of those cheap things they sell near the register at autozone. It was an antenna with a mirror on the other end. Well I taped a magnet to the bottom of the antenna portion, was able to extend the antenna and got them out each time.
In this youtube clip the guy is using a similar device, not sure if it can be purchased at Lowes or Home Depot.
another tip, before you install or remove nut or bolt, use a small piece of painters tape or electrical tape and wrap it on the inside of your socket. it adds friction and makes the socket opening smaller so the nut/bolt won't wobble while you are guiding it in or removing it. if screwing it in, you can actually put bolt/nut into socket first then use tape to wrap edge and secure it wile guiding it to it's location.
Thanks All... I am going to buy the magnet thingy, and try my luck pulling out the lost nuts. For some reason, i am hearing a bit of a 'gritchh' sound when the car goes over small uneven patches on the road, but not on bigger bumps?! I am thinking that the CD changer without the nuts on the top is causing that 'small' but noticeable noise.
Registered User
Head Unit Bolts
Youre not going to find the head unit bolts at a Hardware store. They are about 1 1/2 inches long about 3/8 inches wide. And metric.
Go to the dealer and by a pair. And dont worry about the loose ones. I dropped one about 4 1/2 years ago. No problems.
Most hardware stores, home remodel (Lowes, HD, Menards) carry metric sizes now, even in stainless and yellow zinc plated.
Registered User
Bolts
The head unit is attached with 4 bolts. Good size metric ones. You may find them in a hardware store. If you search.
Or you can buy them from the dealer or Sewell.
To All, and Cartman -
THANK YOU. Today I finally had time to pull out the dropped nuts using that magnet extending thingy and fix the radio snugly. THANK YOU again.
PS - while pulling out the first wood trim around the gear shaft, i made two minor blemishes to the trim - shows up a bit 'bad'... have to live with it!
Ram
Ram
Isn't it a good feeling to have your nuts back. lol.
(Sorry I couldn't resist)
I made the same mistake regarding pulling off the first piece. I use the trim removal tool on the side which left a little knick but not noticeable to the naked eye but each time I needed to go in I did it at the bottom and when replacing panel I did it in the reverse order I removed it.
